To those of you who have installed a rear cobra disc brake set up on a 99-04GT: (this is for a 2003 GT if that makes a difference)
I am upgrading my rearend components this winter, and I ran across this article on modulardepot:
http://www.modulardepot.com/?show=articlesdet&aid=54
Which was something I was planning on doing in the near future so being that my rear will be apart as it is I'll do it at the same time.
My questions are:
1. Are the cobra/bullit rear calipers actually the same as stock GT rear calipers and the the rotors and mounting hardware are the only difference? If so, this is all I should need to do this upgrade being that I would be re-using my original rear calipers:
http://www.gefracing.com/Merchant2/...=G&Product_Code=M2300M&Category_Code=46BRAKES
2. Can I still use my quad shocks with the upgraded rear brakes, the article above had to cut off the quad shock mounting brackets to get the kit to fit. Is there a way to avoid this being that I want to keep them for the time being.
Any input you guys can supply is greatly appreciated.
My questions are:
I read this thread incorrectly my bad
