The car is an 86 fi. It is all stock. I pulled the motor and left the auto trans in the car. The converter is still in the trans, and is where it should be I believe. I went to install the motor and I can get the motor mounts lined up. I can get the top of the motor flush with the bellhousing however, on the bottom the flywheel is not going into the trans like it is supposed to. The motor looks crooked from the bottom. I tried jacking up the trans, jacking up the front of the motor but I cant get it right. Am I not doing something right? I am tempted to pull the trans at this point and install it all as one unit. Any suggestions? Thanks.
