  • 1994 - 1995 Specific Tech
Installing Explorer Intake
  • Thread starter Thread starter scarless
  • Start date Start date Aug 19, 2004
scarless
175
  • Aug 19, 2004
What problems can I expect when installing a 98 Explorer intake on my 94 GT Vert \w AODE? Hearing the experiences of those that who have actually done this would be great! Are there any magazine articles that have covered this?
Can I use my current throttle body?
Any problems with throttle cable, trans. cables, or bracket mounting?
Are there any problems with the EGR tube length, PCV, or sensors?
Do I need to get a new strut tower brace?
I want to install GT-40P heads soon, will I have any trouble passing emissions tests in Metro-Atlanta?
Thanks.
squall9393
534
Oceanside, CA
Aug 19, 2004
  • Aug 19, 2004
I'm currently tackling this myself. Refer to these threads.
http://forums.stangnet.com/showthread.php?t=493193
http://forums.stangnet.com/showthread.php?t=492539
1990LXDropTop
430
Western Massachusetts
Aug 19, 2004
  • Aug 19, 2004
Here ya go buddy, http://www.allfordmustangs.com/Detailed/614.shtml
OrangeMustangGt
1,976
Cape Cod, MA
Aug 19, 2004
  • Aug 19, 2004
i just did one. I did the whole motor, aim me if u need info.
Joes95GT
3,132
Delaware
Aug 19, 2004
  • Aug 19, 2004
Yes, although I would go bigger...
I'm unsure about trans. cables, however, all brackets and throttle cables will hook up correctly, provided you use the 94/95 intake adapter elbow.
My EGR tube fit perfectly. Same with the PCV.
Well, you don't need one, but the stocker won't fit unless you cut and weld it a little bit
You should not since the GT-40P heads and Explorer manifold are all smog legal.
Thanks.
Yup.
Joe
squall9393
534
Oceanside, CA
Aug 19, 2004
  • Aug 19, 2004
Thanks.
Yup.
Joe
Show Off! J/K
Seriously, good info. Taking notes here but now I think after seeing the article 1990LXDropTop added up there I'm looking at a 93 Cobra intake pretty hard.
OrangeMustangGt
1,976
Cape Cod, MA
Aug 19, 2004
  • Aug 19, 2004
the only thing with the gt40ps is that they dont have the rear emmissions corssover tubs. dunno if it will affect the emmissions tho. yeah, and the strut tower, i tried to cut and weld it, it aint even close. Oh yeah, and with the trick flow sn95 elbow, take and port the inner of the explorer intake so its a smooth transition.
Joes95GT
3,132
Delaware
Aug 19, 2004
  • Aug 19, 2004
squall9393 said:
Show Off! J/K
They're the same manifold. I wouldn't waste the extra money on the 93 Cobra just from a performance stand point. If you want it for looks, then that is something different.
The stock STB will fit. I know because I've done it. Of course, you can't just cut and reweld; you will need (about) another 6 inches of tubing. I bought 2 feet just to be on the safe side.
Also, the hardest part for me installing the manifold was rerouting all the vacuum lines. They do not hook up in the same spot as on the stock manifold. With this particular manifold, it doesn't matter which vacuum port you hook up where, as long as everything is hooked up correctly, the car will run fine.
Joe
squall9393
534
Oceanside, CA
Aug 19, 2004
  • Aug 19, 2004
Joe
You got mail! (PM)
squall9393
534
Oceanside, CA
Aug 19, 2004
#10
  • Aug 19, 2004
  • #10
Thanks.
Oh yeah almost forgot! I do this to everyone I can that's a newbie.
"Show us some pics of your car!"
Show that baby off!
Dan95-5.0
1,110
Manitoba, Canada
Aug 19, 2004
#11
  • Aug 19, 2004
  • #11
post pics of your modified strut tower brace.
i was thinking about doing the same when i install my explorer or cobra manifold and then send the brace out to get chromed.
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
95-early 97 Explorer upper and lower intake manifold - NO LONGER NEEDED
  • R82148V
  • Jul 11, 2025
  • Want to Buy
Want to Buy Oct 31, 2025
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
