Installing Rockers - Zero Lash Question
red94fiveo
1,269
Wichita, KS
I just installed my rockers (Comp Pro Magnum 1.6's). I followed the installation procedure, set to zero lash (rotating the pushrod) and then tightened another 1/2 turn. My question is this. After I tighten the additional 1/2 turn, I can't rotate the pushrod anymore with my fingers, which makes sense. But after turning the engine over my hand a couple times during the course of installing all the rockers, I went back and was able to rotate the pushrods again with my finger, wich tell me they have loosned. Is this normal and OK, or do I need to correct something? Thanks.
StormTrooper said:
completely normal geometry has changed since you last rotated, just do a warmed up final check and your in the clear
Sorry, but could you elaborate a little bit. Do I need to retighten them, so just make sure my geometry is OK and do a final check? Thanks again.
GTJake said:
You prime the oil pump by putting a 5/16 (I think) socket on it and just giving it a spin. That way the oil will make it up to the rockers.
Jake
If you got pedestal rockers arms you should tighten them to specs. your doing what it calls for stud mount rockers arms
He has stud mount rockers. I don't see why if would make a difference if you prime the pump whether you have pedestal mount or stud mount.
Jake
Well when you prime the engine, the lifters will get pumped up with oil. When they are not pumped up, the pushrod cam be pushed into the lifter. Thats why they seem so lose. After the engine is primed, the lifters will tighten up and u can check/re-adjust.
