Installing timing chain
  • Thread starter Thread starter fordracing82
  • Start date Start date Jun 4, 2006
F
fordracing82
12
Elkhart, IN
Jun 4, 2006
  • Jun 4, 2006
does anyone have any idea how difficult it is or how time consuming it is to install a new timing chain on a 5.0?? any suggestions?
R
R2D2
Jun 4, 2006
  • Jun 4, 2006
difficult NO, Time consuming Ya. Pulling all those accesories and brackets along with the balancer then the timing cover.
F
fordracing82
12
Elkhart, IN
Jun 4, 2006
  • Jun 4, 2006
will any adjustments have to be made after everything is back together? i'm unfamiliar with this...
vikingpower
656
CWU Ellensburg, WA
Jun 4, 2006
  • Jun 4, 2006
It aint too bad. Put a new front crank seal in when you do it. Also you can reuse the pan gasket so dont cut off the part of it that sits below the timing cover, even though the instructions tell you to
vikingpower
656
CWU Ellensburg, WA
Jun 4, 2006
  • Jun 4, 2006
Also, why are wanting to put in a new one, you shouldnt have to as its a pretty stout double roller from the factory. you shouldnt be putting a new one in until you swap cams
F
fordracing82
12
Elkhart, IN
Jun 4, 2006
  • Jun 4, 2006
a friend of mine was parting out his 5.0 and sold it to me, brand new in package, for $10, so i couldn't pass it up...
rd
3,316
63
109
Ocean Springs MS
Jun 4, 2006
  • Jun 4, 2006
It's not really difficult, but the first time you do it, be prepared to spend 4 to 8 hours, and do it while the parts stores are open. You need a balancer puller. The hardest part is getting the waterpump bolts out if they have not been out before. There is risk of carnage here. Next deal is to clean everything.
Most gasket companies sell a timing cover gasket set just for this. Works great. Should include the front seal.
Drain the oil from at least the front sump before you fire the engine.
Remember the pesky bolts that hold the cover to the oil pan.
Gets easier the next time.
vikingpower
656
CWU Ellensburg, WA
Jun 4, 2006
  • Jun 4, 2006
just wait then, it aint worth the trouble just to put a new timing set in and nothing else
USAF91GT
33
South Korea for now!
Jun 4, 2006
  • Jun 4, 2006
Pull the timing cover and waterpump as a single unit. Saves money on gaskets!
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
