  • SN95 4.6L Mustang Tech
Installing urethane sway bar bushings
  • Thread starter Thread starter 89lxsport50
  • Start date Start date Mar 12, 2013
89lxsport50
550
Franklin Tennessee
Mar 12, 2013
  • Mar 12, 2013
I'm getting ready to install some urethane front sway bar and end link bushings on my '02 GT. Should I support the car on jack stands, or should I use ramps? The Maximum Motorsports installation instructions say to tighten the end link nuts when the car is on the ground to avoid preloading the bar. I wonder if I could just put the car up on ramps for the install and tighten the end links on the ramps?
flstang65
1,484
135
94
SE Georgia
Mar 13, 2013
  • Mar 13, 2013
You will be fine with the ramps
KB00GT
15
Fort Riley, KS
Mar 14, 2013
  • Mar 14, 2013
+1 ^ as long as you have the car weight on the wheels you should be fine
89lxsport50
550
Franklin Tennessee
Mar 18, 2013
  • Mar 18, 2013
I got them in using the ramps. They definatley tightened things up a bit.
Reactions: flstang65
flstang65
1,484
135
94
SE Georgia
Mar 20, 2013
  • Mar 20, 2013
did you do the end links, bushings on the frame or, all of them? going to doing the same thing to mine this week.
89lxsport50
550
Franklin Tennessee
Mar 20, 2013
  • Mar 20, 2013
I did all of them. I did the main bar bushings one at a time first. Then I took all of the nuts off the end links, and pulled them out. I just replaced the actual bushings and re-used the factory hardware. I read somewhere you can wrap teflon tape around the bar where the bushings go to keep them from squeaking. Between that and the supplied grease, I hope to remain squeak free.
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
SN95 Sway Bar Endlink Issues!
  • Swizzy
  • May 10, 2024
1996 - 2004 SN95 Mustang -General/Talk- May 13, 2024
Swizzy
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
C
Suspension spherical or urethane upper control arm differential side bushings?
  • colehelm
  • Jul 3, 2024
3K
Fox 5.0 Mustang Tech Jul 6, 2024
manicmechanic007
