Intake/coolant/ps pump questions
  • Thread starter Thread starter Makdaddymac
  • Start date Start date Feb 9, 2009
M
Makdaddymac
323
orlando
Feb 9, 2009
  • Feb 9, 2009
hey all,
today just out of random motivation i though i could pull my top end apart again to retrq my lower manifold,pull off my valve covers to strip them of there chipping paint job,and replace a whining and leaking ps pump....... got top intake of in 15mins(after my rookie arse took one of the coolant hoses that goes to the tb off while the car coolant was pressurized and hot, so i have a burnt hand now!)
i then spent a 1.5-2hour on replacing the ps pump. i removed the radiator do this, and went faily smoothly but i want some tips on how to get the air out this thing and or recommendations on fluid, i was told to use synthetic atf fluid(same thing) but i just want something that is affordable and good...the car had the original ps pump on it and it worked fine but it was just leaking and whining too much to my liking..
also this is my concern. my coolant which is not old is appearing burnt orange with mild green(lol i know poor description but you get the point).....i use prestone or w/e which is bright green. and cannot see the coolant looking this bad after barely any usage.....what cold be the culprit...
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Feb 9, 2009
  • Feb 9, 2009
The coolant may be discolored from the radiator or rust in the system.
Normally on the power steering I fill it with fluid and turn the wheel all the way to full lock doing this in both directions several times and it will bleed its self of any air.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 9, 2009
  • Feb 9, 2009
Fill the pump up, start the car, and turn the wheels lock to lock to bleed the air out. Recheck the fluid level and repeat this process 2 or 3 times.
M
Makdaddymac
323
orlando
Feb 9, 2009
  • Feb 9, 2009
ok easy enough...
im having fun cleanig these valve covers. i guess the paint did stick pretty well in some area.....but oh well....have any of you guys had luck with putting stickers on the valve covers? i was thinking of going and getting some ford or 5.0 stickers from the custom graphics stand at the mall would cost lke 10.00 total and be a little decorative but i dont know how it will hold up in the heat?
Vinnietbird
584
  • Feb 10, 2009
I polished my valve covers after I took the paint off.Then I sold them and bought Cobra covers.
M
Makdaddymac
323
orlando
Feb 10, 2009
  • Feb 10, 2009
well i cleaned them an applied two coats of clear, they look pretty good actually. and they still look good after being installed where and when grease comes into play. i like this way better cause they are better looking than an old high mileage stock set but also have a "i care about my engine bay on a budget look"....
someone told me that cobra v convers wont work with 1.7's, but i thought all 94-95 cobras had 1.7's and my gt40 are 95 cobra heads and the 1.7 are crane cams which i also believe is stock on cobras.
ps. anyone put stickers excuse me i mean man decals on there valve covers. i got a cool idea to put something on mine....but idk with the clear coat and all
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Feb 10, 2009
  • Feb 10, 2009
I am budget minded on project daily driver as well. I also did some painting while I had mine apart. Its amazing how much nicer things can look.
Heres a before shot
And after
M
Makdaddymac
323
orlando
Feb 10, 2009
  • Feb 10, 2009
yeap!
N
Notch916
Sacramento, CA
Feb 11, 2009
  • Feb 11, 2009
wut did you use to clean the engine bay? I been wanting to clean mine also.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
V
Engine Coolant Leaking?
  • vinzo
  • Jan 26, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
2000xp8
