intake cuestion
aleborjas said:
hi
wich is better between the comp polymer power box and typhoon and wich one produces more power?
http://greenwoodchevy.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=GCGPPEDH&Product_Code=54021
Is that the Typhoon you are talking about?
If yes...
The longer runners will be better suited for 302 displacement motors with mild to moderate mods. The lack of runner length on the comp upper will increase the upper rpm power and decrease the low end torque. I ran my stockish 302 for a while with a comp upper on a cobra lower, and was not happy with the low end. It did not seem to come to life until about 3500rpm (not good for a street car). This will vary with heads and cam though. For a road car I would not recommend short runners on a 302. For a track car (corners or drag) it could be very beneficial.
With larger displacements the short runner intakes become more feasible. A 331 on up will probably be able to take advantage of the short runner flow at higher revs, and still produce reasonable torque.
Currently I am running a comp upper on the 408 stroker. The long runner manifolds are very restrictive to the upper rpms with 351w based strokers, I have seen a couple of dyno tests on these.
Also, I would not recommend the comp manifold for boost. It may be able to hold the pressure, but I will be upgrading to a metal short runner upper when I add boost.
jason
