  • SN95 4.6L Mustang Tech
Intake manifold help...
  • Thread starter Thread starter m0squ1t0
  • Start date Start date Jun 17, 2011
1 of 2 Next Last
M
m0squ1t0
103
  • Jun 17, 2011
What sensor goes there? (Still learning...) part #?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 17, 2011
  • Jun 17, 2011
Engine coolant temperature sensor.
For part numbers try Home Page | O'Reilly Auto Parts.
Was considering looking it up for you, but I don't know the model year of your car.
M
m0squ1t0
103
  • Jun 17, 2011
I appreciate it, just knowing the name helped, I knew it was a temp sensor but now I feel dumb lol. Thanks!
fast97gt
1,082
north carolina
Jun 18, 2011
  • Jun 18, 2011
"There are no dumb questions, just dumb answers"
M
m0squ1t0
103
  • Jun 19, 2011
YouTube - ‪Mustang issue‬‏ guys I need help just installed intake Mani and now this...
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 19, 2011
  • Jun 19, 2011
IMO, we need to determine if this an vacuum leak or an IAC problem.
First confirm that fuse F2.2 and F2.8 are good.
F2=CJB=Central Junction Box,located in driver's kick panel.
Double check for any vacuum leaks. Are all of the lines in place? EVAP purge lines? EGR lines?
Does it run if you hold the throttle open?
Does it run if the MAF electrical connector is disconnected?
Is it missing?
Did you have any issues installing the manifold? Any problems with the gaskets? How did you clean the head surfaces?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 19, 2011
  • Jun 19, 2011
What did you forget to reconnect?
Also did you change plugs or coils when you do intakes? The last intake i did on my mom's Grand Marquis i put in all new Motorcraft coils and plugs when i changed the intake and it ran perfect. Reason i ask is there could have been coolant down the plug holes and make the coil boots swell.
M
m0squ1t0
103
  • Jun 19, 2011
If I hold the throttle open it runs but car shakes, didn't change coils or plugs, looks like coolant is leaking...
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 19, 2011
  • Jun 19, 2011
The coolant in the spark plug wells likely is causing the misfire. The issue now is to figure out if the coolant is still leaking.
Suggest starting by drying the spark plug wells. Compressed air is one method.
If it still leaks coolant, this could also be a source of a vacuum leak.
Did you use a torque wrench to tighten the intake bolts? Follow the pattern? The T-stat cover? New O-ring in the T-stat cover?
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 19, 2011
#10
  • Jun 19, 2011
  • #10
Where is the coolant leaking? Did you use a Ford intake or the Dorman one? If you used the Dorman one did you get all the o-rings in place that they used instead of gaskets.
M
m0squ1t0
103
#11
  • Jun 19, 2011
  • #11
Got the ford racing one from American muscle, didn't follow pattern was told to just torque left then right, looks to be leaking underneath Mani, and yes new o ring in t stat cover... And idk if there is coolant is spark wells will check tomorrow
F
Frankenstang838
37
Tell City, Indiana
Jun 20, 2011
#12
  • Jun 20, 2011
  • #12
You have to follow the torque pattern no matter what anyone says. you're prolly leaking coolant cause you didn't get it torqued right around the water passages. I've done 6 intake swaps, and everytime i do one, i replace every single gasket, o-ring, and inspect every vac hose on the top of the engine. I've only had one fail, and lock washers on every intake bolt and re-torque fixed that issue.
M
m0squ1t0
103
#13
  • Jun 22, 2011
  • #13
Well I've coolant coming out of the exhaust and the oil looks milky. Not going good. Head gasket?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 22, 2011
#14
  • Jun 22, 2011
  • #14
If the coolant is leaking via the intake manifold coolant crossover, it's possible for it to be sucked into the intake valves. From there it's easy to see how this could get into the oil.
Of course it's possible that large amount of coolant was setting on top of the pistons (you did ensure that no coolant made it down the intake right?) during the 1st startup. If so, this could cause hydro-locking. Obviously, hydro-locking can (and does) break pistons, rods, values and most anything else it wants to.
When ever unknown amounts of coolant (or any liquid) have made it into the combustion chamber, it's a good idea to turn the motor over by hand a before restarting the first time.
Have you located the source of the intake leak? A compression test can help you determine if the motor has been hurt.
Sorry to hear about that.
M
m0squ1t0
103
#15
  • Jun 22, 2011
  • #15
So I got a different view from a buddy of mine. He said if coolant dumped into the cylinder then the oil could show milky he said to change the oil and plugs then run it.
M
m0squ1t0
103
#16
  • Jun 22, 2011
  • #16
Oh he also said that the coolant coming out the exhaust was coolant that dumped into the cylinder. And it will stop after it's been expelled from the motor. When I start it it doesn't turn over on it's on unless I hold the gas. When I do that it runs smooth but smoke comes out the exhaust along with the coolant
M
m0squ1t0
103
#17
  • Jun 23, 2011
  • #17
Bump
M
m0squ1t0
103
#18
  • Jun 23, 2011
  • #18
Anyone?
M
m0squ1t0
103
#19
  • Jun 23, 2011
  • #19
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 23, 2011
#20
  • Jun 23, 2011
  • #20
Just wondering what you are looking for.
Have you changed the oil? Is there still coolant in the oil?
Is it still leaking coolant? If so, have you found the source of the leak?
Have you run a compression test?
If it's still leaking coolant, it not just a little that has run down into the cylinders.
We can't help without more information.
It's either an intake leak or the motor is hurt. I guess no one wants to be the one to say, "it's hurt". Sorry.
1 of 2 Next Last
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
D
cooling system on 289
  • DTCRAWLEY
  • Apr 20, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
