  • SN95 4.6L Mustang Tech
Intake Problem?
  • Thread starter Thread starter Davids79
  • Start date Start date Aug 25, 2008
D
Davids79
53
Issaquah, WA
Aug 25, 2008
  • Aug 25, 2008
I have a 98 GT that has had a miss @ around 1800 RPM, I have put new plugs and wires into it and it still runs like $(%#, if you get above 2k it runs much better, It has also developed a coolent leak around the tstat,
What are the signs of a bad intake? what year did they finally fix it? would a bulitt intake work on a 98 4.6l? My fear is that the new part from the dealer is still plastic and would have the same problem down the road, am I nuts for thinking that?
D
darkside03gt
851
Sacramento CA
Aug 25, 2008
  • Aug 25, 2008
if you have developed a leak you need to replace it because its more then likely cracked. You could step up to a pi manifold. its still plastic but the coolant crossover is aluminum. a bullitt manifold will cost you some seriouse cash and wouldnt be worth it in the long run.
D
Davids79
53
Issaquah, WA
Aug 25, 2008
  • Aug 25, 2008
Will I have any clearance issues with the stock hood, I see that livernois has a kit but don't see what is special about it?
J
juecke98gt
Banned
May 31, 2008
78
  • Aug 25, 2008
The livernois kit is just a pi intake with special adapter plates to fit the npi heads because the coolant passages are just a little off and the air passages are shaped different. Some people just rtv it up but I dont really endorse that method but some swear by it so its all about your pereference. When I did my heads and intake I had the water passages welded to fit the pi intake and than I grinded it down but I work in a toolroom so I have all the tools to do this stuff. Also my heads were ported and polished. O and livernois kit intake has the top milled to fit a stock hood.
D
Davids79
53
Issaquah, WA
Aug 26, 2008
  • Aug 26, 2008
Anyone have any problems with an aftermarket PI intake or should I stick with the FoMoCo, The dealer wants $400, summit wants $200, I saw a couple of recomendations around the forums but the links were all dead.
98E9GT
110
  • Aug 26, 2008
I got a Crown Vic PI w/ Alum Cross on ebay for 89 bucks, working great. Really feel a difference.
  • Gulftown980x
  • Jul 29, 2026
squeak93
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
