Intake - Will It Work?
It should fit fine as I believe all the TB's are at 80 mm where the pipe joins up. I would caution against using a 75 mm TB unless though you have an after-market intake plenum to go with it. Expect to see a hp loss if you use the 75 mm TB withe stock plenum.
It'll fit just fine, I had an FIPK and a 75mm TB on my car for 2 years.
Also, its a proven fact (by our good friend the dyno) that a 75mm TB and an aftermarket plenum (especially the Accufab) are good for a couple ponies to the rear wheels. Even on a setup as mild as this :)
-Will
-Will
my stock intake hose fit over the Accufab 75mm. Also if your going to go with cams then go with the 75mm. You wont out grow it and have to buy one latter. The HP is noticable and the only other thing I have are UD pulleys. I think it was a great mod.
hey guys i am looking at buying that setup too and i want to know if a 75mm TB with plenum would be too bic for my application. i will have longtubes and off-road h pipe soon so would the 75mm be too much or good??
