pretty much any fmic will do for that setting, i have not heard of anyone having any trouble with a volvo fmic
15psi or a little higher. IC's with the inlet and outlet on the same side are usualy small (if your looking for a junkyard pull) ive seen one on a talon, dodge laser, and a carpi (australian made) ..all these are quite abit smaller than the svo stock ic, so in my opinion thats a Step backwards. You could take a Turbocoupe(flows better than the svo one a little) intercooler and fab it up to be a front mount, its a good flowing IC and as a front mount it would cool nicely (for cheap).
the fuel switch is not confirmed to mess with timing that i know of, it is generally though to do so (along with uping the boost)...
higher octane = safer timing advance + boost.
You will also want to be thinking of piping for your front mount ic, dont go with anything less than 2.5 inch tubing, I've been informed it makes it hard for the motor to breath up top with anything less. I have 2.5inch running from the turbo to the intercooler, and 3 inch running from the outlet to the throttle body, seems to work great.
Put a gilis valve on there and have abit of fun, your missing atleast ~35hp from stock (15psi) by only running 10psi...just be careful to tune it slowly and not blow anything up! Crank the boost in small increments and LISTEN for Pinging...unless you like changing head gaskets like me
