I saw somebody on these forums with an old KarKraft functional hood scoop conversion kit, seen here
http://www.mustangweekly.com/2000/august/newprdts/npp29.asp
The article explains it's installation and you can get a good idea of what it is. I was very interested in this kit since it used the stock hood and hood scoop rather than the mach1 system that replaces a bunch of stuff (and because of that, is very expensive)
However I saw that they were discontinued. I emailed KarKraft and got a response in one day, and it looks like if there is some interest it's possible to get these things rolling again. In fact, a simpler system with the stock airbox and no vacumme flaps, which I don't think is really neccessary anyways.
So what do you guys think? I'd put this in my sights as the next mod I get if they come back out. I hate how the hood is fake, but it looks to good to take off. This would solve everything
thank you for your interest.
we appriciate your interest in the ram air system. we have had a lot of requests to bring back the system. we had discontinued it due to the high labor hours it took to assemble it plus the vendor who made the vacuum motors went out of business.
we have had thoughts on bringing back the system in a simpler form using the stock GT hood scoop either from the 99/00 or 01/04. we would use the under hood plenum from the original system except not make mechanical. we would eliminate all the flappers and vacuum motors. not sure if all that was necessary anyways. we would have to come up with a piece of duct that would extend down from the RH corner of the plenum to the factory air cleaner, similar to the 2003/04 Mach1 that used the stock air cleaner with a hole cut into it from the shaker. this way it would eliminate the cost of an air cleaner as well. get some ideas if that would work to the internet crowd and let us know. we could probably do something like that pretty fast since we still have al the tooling from the original system. if it weren't for the labor intensity, we would have continued the system. we probably get 6-10 emails a week asking for the system.
thank you for your interest,
