interested in a set of twisted wedge heads
inphiniti
412
39
Providence, RI
can anyone make any suggestions? i have a goal of about 400-450 eventually... perhaps more so 450 in a few years with a blower of sort... i currently have a trick flow street heat upper/lower and will be running a custom grind cam from FTI :nice:
thanks in advance guys!
The twisted wedge are good heads, the reason I bought them was because there port potential. Basicly you will not have to buy another set of heads again.
The TW have so much meat on them that can be taken off and can be ported to out flow 185's.
AFR make good heads too. Either one is not a bad choice.
You want to make 400-450rwhp with Twisted Wedge Heads:
N/A
Dart Block 8.2 deck
364 CI
Twisted Wedge Heads set up by Ed Curtis
Custom Cam from Ed Curtis
Ported Vic EFI manifold
LMAF
42 pound injectors
75MM throttle body
Custom Tune
Super Charged
Stock Block, Bore, Stroke
Twisted Wedge Heads out of the box
Track Heat Intake out of the box
75mm Throttle Body
42 pound injectors
LMAF
Kenne Bell 2.1L w/9#s of boost
custom tune
There are a million ways to do this, it really depends on what you're looking for in terms of stroking it, power adder, budget, power band, etc etc etc
Adam
N/A
Dart Block 8.2 deck
364 CI
LMAF
42 pound injectors
75MM throttle body
Custom Tune
Super Charged
75mm Throttle Body
42 pound injectors
LMAF
custom tune
Adam
yeah teh second one sounds more or less the path for me at this time... eventually id like to build a 331 stroker or a 347 stroker... but thats later on...
my basic question is, there are SOOO many TW heads... i dont know which one to go with?
I believe you want these
TFS-51400004
I think you want the 4's not sure which I actually have off the top of my head just know they are non-o ringed cuz no blower or anything atm. I do love my heads the only thing you have to watch out for is when putting spark plugs or exhaust bolts into these heads because they are aluminum and soft. but not to bad plus the ability to port them is a damn good plus. :flag:
TFS-51400004
yup! summit sells the little track heat and street burner kits... those are the heads from the street burner package, those were the ones i was looking at... so match that with a nice custom cam from FTI and i should be good :D
Get the Trick Flow H/C/I package and throw on a supercharger that will get you your goals since you said thats the more direct route you want to take. The Trick Flow package is cheap over all when compared to everything you would have to buy seperatly and its all meant to work together.
