Interior Swap Possible "Without" too much mods?
2manypony's
25
Has anyone taken the seat, front and rear, out of a 2000 Ford Mustang GT and installed them into a 1990 Ford Mustang LX before? Both drivers seats are power, but I'm concerned about the seat tracks. I believe I seen or can by some adaptors from Mustangs Unlimited, but will the rear seat even be close? I was looking at a nice leather interior, but need to know pretty quickly or I'll have to pass on it for right now!! Thanks for any help...
Is your car a coupe or hatch? I have 2002 seats, front & rear in my hatch and I was able to make the rears fit with a few minor mods using the Fox fold down seat back and latch setup. Here is a thread with some pics. Scroll up in the thread or look in "my garage" for pics of my interior:
http://www.corral.net/forums/showthread.php?p=3870560#post3870560
I still have to work on the seat bottoms a bit. They are just sitting in place now, but "one of these days" I'll finish it up and mount them securely.
As for the fronts, they are a direct bolt in with the 2000 seat brackets. If you use the Fox brackets, you will need to probably drill new holes and shim up the seats with some washers or something as the bottoms are not flat like the older seats, but they can be made to work. If you keep the power track, you can just hook it up to your power lumbar harness. I have a picture of the jumper harness I made for that if you want.
Thanks!
I was getting worried nobody out there had attempted this yet, but I didn't think that was possible with all these horsepower people out there. I'll check out your link. Thanks Again!!!!!
The front seats bolt right in with the tracks. I have read that they sit a little higher and if you are a tall guy then your knees might hit the steering wheel. Most people have installed tilt columns to solve that issue.
The rear seats will take a weekend of fabrication, and seems like a lot of work, but I think it would be worth it when it is finished.
It's going to be my new winter/weekend project
Thanks! I think I going to pick up that newer interior and install it over this winter. I've seen a couple Foxes with new interiors now and they look so much more comfortable. Besides, the guy I'm buying this other chassis off of had just sold the original interior out of it, so what better excuse!!:nice:
1991 Hatchback
I put cloth front seats out of a 95 and they bolted in with no mods. For the rear seat, I removed the cover from the 95 rear seat and installed the 95 cover on the original 91 rear seat frame. The seat backs fit well and the seat bottom fits decent with the bottom corners being slightly ill-fitting but not very noticable.
Did you try the later model back seat first?
Did you think that the newer seat wouldn't fit in the back, or did you try? I'm just curious if you tried it both way and decided it would be a better overall deal if you used the older frame with just the new seat cover on it. Thanks!
Are you asking about the rear seat bottom, or the backs? I've seen a few pictures of the seat bottoms where people have used the newer seat fabric and installed it on the Fox seat frame. It is not a perfect fit, but it can be done, and IMO would need to be professionally restructured to look 100%. To save money I just used the whole 2002 seat bottom. That way I retained the SN95 "bucket seat" look instead of the totally flat look of the Fox rear seat. As I mentioned in the other thread I linked to above, the cushion needs to be altered on the bottom (foam cut away and metal frame bars cut down) to fit in the Fox space, and the car will need a 2x6 wall installed behind the doors across the car to mimic the SN95 cars if you go this route.
Another option a friend thought of is to use the Fox frame, but somehow cut out or form the bucket seat shape in the foam like the SN95, and then install the cover on the seat. That way you keep the bucket seat look and have it mount the same as in the Fox. Since I have not permanently attached the seat bottom, I might look into this option. But I know it would need an additional piece of seat material across the front edge to cover the foam properly and look stock.
As for the seatbacks, in a coupe you really need to use the complete SN95 seatback assembly and just screw it to the car with minor trimming of the metal seat frame. I have pics in the thread above of seats in a coupe also, at the bottom. The SN95 frame will not work in a hatch since you need a solid back to attach the frame to. That would require installing a solid bar across the car by the rear speakers to support the seat frame.
Really anything can be done, it just depends on how handy you are or if you want to spend a couple of hundred having someone custom fit the fabric to your Fox frame. I chose to go the cheaper, easy route. Mine took me probably about 3 hours total to install it, including installing & removing the seat bottom many times to figure out how much foam to cut off, and also figuring out how to make the Fox latch hardware work inside the SN95 fabric and foam. Certainly not a long project, but not a simple bolt on either. Also, I've seen a few pics where people have replaced the top fabric on the seatbacks with a new solid piece to eliminate the hole in the top. That gives them a good replica of the Fox seat backs, without the need to install the plastic trim or a headrest to "finish" the seats out.
I didn't try with the 95 rear seat, I just decided to switch the cover over. From what I've read i think that making the 95 rear seat frame fit is about as much work as making the cover fit on the original seat frame.
I've gotta bring this thread back.
I bought a set of black leather seats (front and back) out of a 2002 GT and installed them in my car. I'm 6'1" and I don't have enough head room in the drivers seat. My knees are fine against the steering wheel, but I can't sit up straight. What can I do?
I tried installing the original fox seat tracks on the 2002 passenger seat, and it bolted right on, but it doesn't seem to make the seat sit any lower. What other options do I have?
Edit: By the way, my car is a 1990 Lx Hatch
Has anyone attemped to put them in a vert I have a set of eat I just got from a 99 and was wondering if the width of the rear would be better in a vert. My car is an 86 however it has the 90-93 rear panels in it allready.
