Recently since the rainstorms have started falling here in FL over the past week or so, i have been feeling a pretty steady misfire feeling only when my car is in cruise or at a steady speed it feels almost like a misfire like it is bogging and this feeling happens every few seconds or so. No check engine light and I have retarded the timing one degree in my predator too to play it safe.
I am going to give her a needed oil change tomorrow or the day after and I'm probably going to give the M1 Extended Performance a try.
Could it be the oil, or should I pull the plugs? Or could it be the fact that my exhaust is hanging a decent amount lower than normal and its path isn't as straight and level as could be?
, if at all, if your thermostat is opening too early, than your car temp monitor would read it. Seems like a simple fix.
