Intermittent Cel
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Got a weird one. After installing the Taurus efanm FAL VSC and U/D pulleys, after about 5 minutes ( car goes into closed loop?) the CEL comes on. It stays on for maybe 10-15 minutes and then will go away. If you turn the car off and then back on, it is not there but comes back on after another 5 minutes.. I've run for codes and also brought it to a Mustang shop where they ran for codes and nothing.
Wondering if maybe it is one of the following
1) Bad ground wire
2) I tied into the overflow coolant ignition on for the fan, Maybe it is tripping the CEL.
3) 02 going bad- would think it would throw off a code
Kinda stumped on this one.
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
See AutoZone Part Number: 25886 , $10
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30-$36.
I'm not sure if I'm supposed to bring a thread this old back, but I have the intermittent CEL.
I changed plugs and wires...hard to introduce a problem with that, but I will be asked what I've done to make the CEL start.
Car runs well, no drivability issues, as good of mileage as I can expect. But CEL comes on intermittent or even "flashing" for about the first 10 miles of my commute. Generally shows up around 2k RPM for a couple of seconds, maybe 20 at most, then goes out. Doesn't appear to be tied to the RPM of the engine, or the position of the gas pedal, but the CEL usually lights more often on acceleration than on decel, and rarely to never on downshifts.
I've dumped codes and I have no retained codes, nothing on KOER. I need to be driving. I can rev the engine past the 2k and no light, but while the car pulls it's own weight there is the light.
My thoughts are a ground somewhere or maybe that stupid Drake LED dash light kit I installed 6 months ago. BTW they don't give you an LED for each bulb, so yea, I have some standard dash bulbs still in there (like the CEL, e-brake and...one other one). The rest of the dash is working just fine, only the CEL coming on and then off.
No code 11 (two flashes when the computer dumps the codes)? A perfectly functioning system will always get a code 11, it is the everything is OK code. The 11 code is computer passed its internal self test.
If you don't get an 11, you have computer or wiring problems.
Please check and repost.
