Before I start troubleshooting by throwing parts at this problem ($$$$), I thought I would throw it out and see if I could get some quick insight here. The car is a 95 GT that appears to still be bone stock. I have looked at the crank, no start checklist and couldn't see where this would be of much value to me because there wasn't a "cranks but intermittently won't start when the temp is below 55 degrees and the car hasn't been run in 12 hours or more" section. That is a good description of the problem though. When I try to start the car for the first time of the day, it cranks strong but won't start. I hooked a timing light up while it was cranking and it does not indicate a spark. Sometimes if I try a second time, it starts right up. Sometimes I let it crank for 10-15 seconds with no spark then the next time, I get spark and it fired right up. Sometimes I have to do this 3-4 times before I finally get spark and the car starts. Sometimes, I just bump the ignition a couple times and then crank it and it will start. The coil was replace just about 400 miles ago by a mechanic who thought that was the problem but it didn't fix it. What could be the most likely cause for this and why?
