  • SN95 4.6L Mustang Tech
Intro/problem thread
  • Thread starter Thread starter frequency101
  • Start date Start date Feb 2, 2011
F
frequency101
9
  • Feb 2, 2011
Well hello every-one, this is officially my first post on the forum.
First, a little about myself, I recently purchased a 99 GT 5-speed from the dealership I work at (wholesale, no warranty, etc..). I work in the parts department, so I am able to get allot of help from my master techs, and access to scanners. The only problem is that the ford rotunda current is in-op... Anyway, its my first mustang, and hell, I've never owned anything besides a chevy (I swear it was coincidence), and I've owned 3 LS1 camaro's, a Z06, and I currently own a ls1 corvette as well. I purchased the GT as a good commuter, but its already given me a couple headaches in its first day...
The major problem!
-No start, no crank, no clicks, nothing. Stuck at my work in the parking lot. No after market electronics.
When I first purchased the car, I installed a new battery, and changed the oil. Car was starting prior to the new battery, it just tested bad, so I replaced it to avoid any problems. Car started fine and drove fine about 10 starts after that with no issues at all. Today, I get in the car to drive to lunch, and I got the no start issue. The only thing I noticed was the theft light on the dash would blink after I removed the key.
Now, from what I've been told the blinking theft light means the car needs a new key, while if the theft light stayed lit, the PATS system itself had an internal error. Also, I do not know if the theft light normally flashes when the key is removed...
Which leads me to the starter solenoid. Is the solenoid another potential area to look at? Is it common on these? During the entire time since I first saw the car, starting has never been an issue. Started right up every time for about a week and a half.
I did not pull any codes for the PATS system, but I did get a P1233, which leads me to the second problem
-Slight hesitation under accel
This I think is wired down to the fuel pump module, but is there something else I should look at? I really want this car running asap... I am really anxious to drive it. /the car has a bunch of new parts on it already, and is asking to be driven...
Thanks for any help you guys can provide... heres a quick picture of the car during an inspection prior to purchase...
F
FordTaurusSHO94
110
  • Feb 2, 2011
You sure it's a 99? I would guess 2004 just from that picture.
Edit: I forgot about the anniversary cars.
VOORHEES
Stangnet's "35th Limited Edition" VIN Guy
3,046
36
119
LaGrange, GA
Feb 2, 2011
  • Feb 2, 2011
Yep, 1 of 515 in white. 1999 35th Anniversary "Limited Edition" 4,628 built in 1999. 4 colors available.
trinity_gt
3,125
81
99
Canada
Feb 2, 2011
  • Feb 2, 2011
Nice looking car. You sure it's a 99 with that hood scoop? I thought 99s had a V6-style hood... Maybe not. In any case, those wheels look good with that colour.
The theft light blinks about once every second or two when the key is out.
Re No cranking:
If the car has a manual transmission, you might check the clutch pedal position switch. A scan tool should give you access to that.
If you turn the headlights on and attempt to start it, do the lights dim at all? Or go out?
VOORHEES
3,046
36
119
LaGrange, GA
Feb 2, 2011
  • Feb 2, 2011
The major problem!
I had a similar problem on my 99 GT(also a "Limited Edition" GT). BTW, great looking car.
In about 2006 I experienced a problem where the car would not crank in cold weather with temps below 60 degrees. The theft light would blink but not crank. It would turn over though. Once the temp got above that 60 degree mark, car would start just fine. Got it to the dealer and they replaced the module that controls the PATS system. Not sure if this is the same problem, but who knows. It was a $150 part and was replaced in 15 minutes.
Maybe this helps.
-Jason
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Feb 2, 2011
  • Feb 2, 2011
thats the 1st 99 ive seen with that hood, spoiler and side scoops..looks like an 01-04...
no helpful advice here but the car looks really good
VOORHEES
3,046
36
119
LaGrange, GA
Feb 2, 2011
  • Feb 2, 2011
Little website with info....scroll down page
Mustang Special Editions, Production Info
BTW, in 2000 the "Spring Feature" GT's had the same hood scoop and side scoops.
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Feb 2, 2011
  • Feb 2, 2011
weird....i wish mine would have come with those scoops and that hood...
thanks mr voorhees
patman0911
2,287
Tuscaloosa, AL
Feb 2, 2011
  • Feb 2, 2011
When you turn the key to the 'run' position, does the car power on normally - warning lights come on, seatbelt & door chimes chime appropriately, radio and HVAC fan come on? Does everything come on strong, or do they come on slowly and weakly or come on at first and then get weaker and then die?
As Trinity asked, what happens when you turn the key to 'start'? Lights get dimmer or go out? Put a voltmeter on the battery and see what happens when you try to start it - does the voltage drop way down?
Check for loose or corroded connections at the battery.
Will it crank with a jump? If so, test the battery and alternator again.
Even though you put a new battery in, it could be a dud or whatever killed the last battery could've killed this one. My experience with batteries has been that they don't give you much warning anymore that they're dying and modern cars won't run with less than a healthy battery and it may not even attempt to start if the battery voltage is below a certain level.
Once you're sure the car is getting good power from the battery, then you can start looking at other areas.
F
frequency101
9
#10
  • Feb 2, 2011
  • #10
Thanks for the reply's guys,
Ok, so our locksmith is going to take a look at the car tonight, and he does have a working rotunda, so we can at least access the PATS system, and see if that is at fault or the key. The battery voltage does not drop when trying to start the car. All lights on the dash work normally as i the car will start.
For ****s and giggles I did try to jump it with the same results. No click, or any sign that its trying to turn over. Once we finally get the ford tool we'll check the neutral safety switch and see if thats another cause for concern.
So last question, can it be the solenoid on the starter, or does the theft light basically eliminate that?
Also, for the hood scoop and side scoops and stuff, its defiantly a 99, some one has modified the car very tastefully, which is why I purchased it. I wouldn't be surprised if they updated the scoops and spoiler.
patman0911
2,287
Tuscaloosa, AL
Feb 2, 2011
#11
  • Feb 2, 2011
  • #11
I believe PATS only disables fuel/ignition, not the starter, so the engine will still crank but will never fire.
F
frequency101
9
#12
  • Feb 2, 2011
  • #12
Interesting... I guess its time to check the starter on the car. I guess I'll ask around about that. I'll check the solenoid, neutral safety switch, and starter itself. Thanks for the tip.
VOORHEES
3,046
36
119
LaGrange, GA
Feb 2, 2011
#13
  • Feb 2, 2011
  • #13
So let me ask you this, does your GT have the silver and charcoal two-tone interior/silver gauge cluster/door panels? I can see you have the correct rocker molding for a "Limited"(yes, they are different than a regular GT) if so, its a "Limited Edition".
-Jason
F
frequency101
9
#14
  • Feb 2, 2011
  • #14
-Jason
Yes it does. So its a limited edition? I guess thats cool.. haha.
VOORHEES
3,046
36
119
LaGrange, GA
Feb 2, 2011
#15
  • Feb 2, 2011
  • #15
I think so.
I can tell you what number you have, if you send your VIN# to me via Private Message.
You might want to check out Special Production - 35th Anniversary at StangNet
F
frequency101
9
#16
  • Feb 2, 2011
  • #16
I'll send it over when I finally get car running. Its stranded at my work right now, so I wont be able to pull the vin until then.
F
frequency101
9
#17
  • Feb 4, 2011
  • #17
Well good news! My locksmith discovered a secret kill switch that I accidentally messed with when I parked it that night... Needless to say I got the car home, which is a huge relief.
When I got it home, me and a friend swapped the intake, only to notice its been leaking for a little while. The passengers side spark plug holes were filled with coolant. The intake has been swapped once already, but some-one went silicone crazy. The intake was busted under the thermostat, but was obviously leaking every where else. We cleaned up all the silicone, and put dielectric grease on the coils and plugs, but apparently that wasn't enough to prevent a misfire.
The new intake went on with out a hitch, but the car developed a serious mis-fire. We hooked up the scan tool and noticed cylinders 1,2, and 4 were mis-firing. 1-4 are all on the passengers side where the huge coolant leak was. Obviously the coolant destroyed the coils, so I replace those three. Mis-fire is gone, and car runs like a champ now.
Yeah, I should replace all 8, but I didn't feel like spending $300 today. Also, the other coils aren't showing any mis-fire, so I'm not going to mess with them. Anyway, car is home safe, parked next to the vette, so all is well finally...
Voorhees, I'll send that vin when I pull the paperwork out of my car... thanks fo the help every-one !
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Resolved 1996 PATS help needed
  • Bajaboy
  • May 21, 2025
SN95 4.6L Mustang Tech May 23, 2025
Bajaboy
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
