I had it at 15 and it ran fine, so I decided to bump it to 18 just for the heck of it. It seems to run great, no pinging, and I use 93 octane. I guess what I'm wondering is if it is okay to run it this high if the car is showing no negative affects. It's hard to tell if there is a lot of difference, but should it theoretically run stronger with the timing advanced this much as long as there is no pinging or other side affects or will I get the same benefits at 16? I know going from say 10 to 12 or 14 makes a difference, so wasn't sure if going up 2 or 3 more would help or hurt. By the way, I have stock heads, intake, cam. My only mods are o/r x-pipe and flowmasters, 76mm maf, 3.73, K&N, and 190lph fuel pump.
) Thanks
