Is 18 degrees advanced too much timing?
1. Wow, you dug this one out of the graveyard. 13 years ago was the last post.
2. 18* on stock iron heads probably isn't peak power, even though 25th said it was in his case. This is because the stock timing indicator may not be accurate. Without putting it on a dyno, you won't know for sure.
3. Running near the ragged edge is not a great idea for reasons stated by Hissin. You get bad gas one time, and detonation could do some damage. Leave yourself a little room. I like 14* on stock heads. 16-18* on aluminum heads.
Reactions: General karthief
