is a cam with 222/230Duration , 544/544lift to much for S/D
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
here's some spec's on it
Ultra Pro Racing cam part # EHR 69340-71340. It is for use with a 1.6 rocker ratio. Duration 222/230, lift 544/544.
Will this work with my car....I want that wicked lumpy Idle sound with good low end power. I don't like to take my car past 5K to much...even 4500 is good enough. Or can anyone recommend a good cam for me
S/D and cams
Yes it is....if you want to change cams you need a mass air conversion...there is no way around it for a street car...a guy years ago named Lee Rutter had a wickedly fast normally aspirated s/d car for the track that ran low 11's as I recall
One other question...why would you want to look at changing components while avioding the swap to mass air? Cost wise and time wise the swap is MUCH easier than any head/cam swap...honestly it's easier than most modifications and removes alot of the limitations SD creates for the average stanger.
This is from 50tech.com
Mass Air vs. Speed Density
This article details the differences as well as the pros and cons of a Mass Air System vs. a Speed Density System in all style mustangs. The basic tools and procedures are outlined in addition to tips suggested by the author.
Required Tools:
1. An open mind
Information:
With SD the area you want to watch for is the cam. Once you go over 220* [email protected], then your idle can become unstable and can start surging etc. SD likes High lift, low duration cams, since it relies on vacuum. Most people switch to MAF when going with much larger cams, but if you stay within reasonable limits, SD will run just fine & hard. My 347 runs great with SD although I have pushed the cam limits a bit far with it, but I knew what to expect and with some fine tuning it's not that bad for ME. With SD, heads, intake, gears, blower, N20, all the goodies can be used and have no problems with it. MAF will give a more precise A/F reading to the computer since it reads & adjusts BEFORE entering the motor where SD reads AFTERWARD'S, and thus MAF gives you just a slight better off idle throttle response, a more precise A/F metering, and doesn't rely on vacuum in the way SD does, but I've also seen many MAF cars encounter surging problems (modded or not), unstable cruising modes etc as well, all the things that many claim is an SD problem. If you have done any in depth research you'll find many people still have SD with blowers etc and have absolutely NO problems. SD has a better fuel curve at higher rpm than does MAF (until MAF is tweaked or modified)
Early 87 5.0's had a little more aggressive cam than what was used in the mid 87-89 5.0's which then were changed again in 1990. If the date code on your 87 5.0 HO is before 4/87, then you have this odd cam. It's not widely known about this oddball cam. The difference being it had 276/276* vs. the later 276/266 cams, plus a slightly more aggressive ramp rate. This particular cam works extremely well with 1.72 RR's, giving you a total lift of .475 and [email protected] of 209*, and a 115.5 LCA. It pulls very hard right up to 5800 RPM with good exhaust, intake and reasonable gearing (3.55's or better). I am currently trying to find the Ford Part# for this cam as back in 1992 I read in a Ford Motorsport parts book the different part numbers for each cam. The reason I mention this cam is simply because it came only in early SD 87's.
Don't get me wrong now, there comes a time when MAF IS needed, unless you go DFI (Digital Fuel Injection) and with that, you can tune your motor till your hearts desire. I have discovered that having even a basic off the shelf computer chip (Module) help with minor idle issues. Some off the shelf chips will increase your advance rate in the distributor, alter your fuel curve, richen up the motor at WOT as well as add 4* to your total timing which other than a small boost in HP & TQ also allows you to keep your stock setting of 10*, thus making it easier on your starter motor to turn over the motor. I have heard all the rumors about many aftermarket chips doing nothing and being a complete waste of $$. I'm curious if those people who make these claims have actually dyno'd their cars before and after the chip install for absolute verification. Personally, I highly doubt it. I cannot speak for all of the manufactures out there as I have not tested them. I can only speak for the Hypertech Brand, which I personally used for 4 yrs and had the motor & car tested for what changes occurred. This is where my information comes from as listed above. I was pleased with the overall results of the chip, although I think pricing is a bit high for any off the shelf chips.
One key note here, I always recommend a custom cam AND a custom chip when using SD and a moderately modified motor, but it is not necessary with just basic mod's such as intake, heads, headers, gears, exhaust and roller rocker arms. SD also is more sensitive to fuel pressure settings; TPS settings, idle settings, as well as all your sensors, so make sure they all are in good working condition.
The biggest cam you will want to go with using SD is the comp cams 276hr-14 . Im currently running the nx264-14 which sounds nice but not as lumpy as your looking for.
Roland69 said:
do you have spec's on the 276hr-14 cam...maby a sound clip
this cam is very very good cam is good for SD cars and supercharger or nitrous engines this cam is good al around torque, power etc..
cam spec's
Intake Duration at 050 inch Lift:220
Exhaust Duration at 050 inch Lift:224
Valve Lift with Factory Rocker Arm Ratio:0.544 int./0.560 exh. lift
Lobe Separation (degrees):114º
