Is a strut or shock tower brace noticeable
You'll only feel a difference if you make hard turns.
SRT Handz - I would check it out first, there were other reasons why ford dropped it in 98 besides cost.
o3redfire - If it's connected at the right places it will.
Kilgore Trout - Unless you use it for a real use like coilovers
squares98 said:
I noticed my kb strut tower brace immediatly, but like tom said its really only noticable in hard turns, and maybe pulling into driveways
I agree with this. I also felt the difference right away, but with fast sharper/shorter turns. Not so much on a long fast curve.
As far as installation, the one that I bought (3-Point Brace) had 2 options for installation.
Either tap the screw holes and screw the bolt right in, or just drill the proper size hole and a use both Nuts and Bolts, but you have to reach up throught the fender well.
ADVICE: Be very carefull when removing the cowl strip that goes in front of the windshield. Do not bend it too much or it will crack! :bang:
been there done that ^^^
its pathetic how bad mine cracked when i took it off. but there is a certian procedure to remove the cowl you have to unbolt the window pillar covers on both driver and passenger sides. which i never had a clue to do not untill i got the instructions with the new cowl
i had to shell out 140 for a new cowl cover.
i wish they had an aluminum or metal replacement for that cowl cover
That's some good info! Thanks :nice:
BTW, where did you get your replacement? I've yet to get mine.
WOW! $140 That bites,...... :nonono:
this is why i had to get mine the next mornin LOL
also when you undo the bolts for the windsheild pillar cover slightly separate them dont pull them off completely the instructions are provided with the new parts. so give them a once over before installing
