I shift mine at 5800RPMs. I have heard of guys running the GTs to 6200-6800 in autoscross events (not stock LOL, but I belive the bottomend was). They would loose a quart of oil every 30mins. Supposedly thats what leads to spun rod bearings...the oil lv will drop to 3-4 quarts and then there is shortage and the bearing spins. If your shifting abouve 6K, I would check the oil regularly....seems to be a ton of blowby with the GTs. DOHCs may be designed differently, but i have heard of the oil misteriously getting low in them.
, im not sure about the exhaust but it waas loud (im all stock with exhaust also). However, i think getting her up beyond 4k rpms lead to my intake failing and cracking sooner
i knew just by revving under the hood from the throttle cord and seeing water/coolant squirt @ high rpms i was going ot have problems. Hehe, well after acouple days of getting her up high my intake got worse and worse. However, when shes fixed she will see more RPM's than 2000k-3000k :nono
