" is it worth the trouble "
dartvader
61
Aruba
a friend of mine gave an decent offer on my AFR 165, not that they are for sale :nono: but I tought maybe if he wants them I can go with the 185 and have my performer rpm ported by T- Moss or get a Holley intake.
what do you guys think is it worth the trouble et wise ??
and yes i have notched flattop pistons........
Theres a lot of room for improvement with your plans BUT you will need another cam from Ed to maximize it and you'll probably need more gear and have your stall restalled. I believe Ed still has a trade in for cams, your old FTI cam + $150 gets you a new cam.
I think as it sits you have a nice combination. Any numbers on it?
well I only got to go to the track once and only made one pass started raining,
13.09 with a 1.80 sixty foot,
this with 10* base timing 33*total
no underdrive pullies or short belt
and later found out the tune was a little rich
i think it would probably go high 12 but i have to wait till they open the track back in February.
sorry no dyno numbers
well Grady, the last time Ed was here we talked about it :Track:
he told me I would need another intake and it would work with this cam, he could make another cam for me if I wanted to make 100% benefit from the new setup = (more rpms and more gears )
I wanted to see if I could get some feedback from peeps that have actually done it.
but i'm probably going to end up doing it anyway ..:D
cause you know I like working on mustangs :nice:
OK I got some time to speculate :D
Lets compare the typical NA AFR165 head ... Edel intake ... FTI combo we
have all seen here :)
They've all produced about the same ... 300rwhp give or take a few
except
One that went 326 :eek:
It did in fact have a ported lower ... so ... that is something to think about :)
1) You could pick up a bit more power without the head upgrade
Another option :D
2) Seems to me if you did the 185 heads AND either had your lower ported
or did a Holley intake ... you would gain more power than #1
however
#2 Would be a good bit of trouble and expense :Word:
I would wonder if it would be worth it
You know what ... I kinda see it like this ;)
Kinda like a fellow who builds up a nice NA oem block based combo with
all OEM stuff such as GT40 heads, Cobra intake, & e-cam
He then decides to go to an all after market combo with the h/c/i,
same block, and stay NA
Sure ... More power ... but ... Is it worth it
I've often thought the best thing for me would be to sell my h/c/i as a
package for maximum return on my dollar spent.
Then do a combo that will make significantly more power such as an all
motor 347 or KB on my current OEM block.
I kinda see these combos as stepping stones :)
I wanna make sure my next step upward is one that delivers good power
for the amount of buck spent :banana:
So ... there you have it :D
I didn't do anything to help you :bang:
except
Ask the same question :eek: ... Is it worth it :rlaugh:
Grady
