Is MSD 6BTM needed on Charged car???
  • Thread starter Thread starter ARMAGEDON
  • Start date Start date May 29, 2009
ARMAGEDON
100
May 29, 2009
  • May 29, 2009
Hello All,
I just bought this car.
The car has an MSD 6BTM mounted but not hooked up.
I will eventually get around to hooking it up.
My ? is: How important is it to have the MSD working on a charged car & do you really need it?
The car seems to run strong without it.
Thanks for your input.
Basic Mods:
Powerdyne (9 Lbs.) Cobra Upper & Lower (P&P, Extrude Honed), SVO Aluminum X-302 SVO Heads (P&P), Forged Pistons, 306 Block, 65mm TB, 75mm Mass Air, 12" Cone K&N, 4" Inlet Tube, 30 lbs. Inj., 255 Pump, MSD Blaster Coil, MSD 6BTM, Electric Fan, BBK Shorties, , H-Pipe, Cat Back, 3:55's, Stock ECM, Etc.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
May 29, 2009
  • May 29, 2009
The 6BTM has an adjustable boost/timing retard function to allow you to adjust timing based on manifold pressure. This in turn will allow you get more aggressive with your timing yet prevent detonation under load. If its there, you'd be leaving a lot of power and safety on the table without running it.
That being said, if you still choose not to run it, there's no sense having it mounted there in the first place. You're shortening its life span with the bouncing around, heat/cooling cycles and unnecessarily exposing it to moisture. Its kind of one of those **** or get off the pot things.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
May 30, 2009
  • May 30, 2009
If it works, hook it up, supercharged applications are one of the few times the msd stuff is actually needed.
Fuel My Car Needs To Much Fuel Pressure... I Think?
  • sen2two
  • Aug 22, 2014
Fox 5.0 Mustang Tech Aug 23, 2014
madspeed
Black Jack: Dragstrip tuning. New records
  • FastDriver
  • May 29, 2015
  • 46 47 48
237K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 10:46 AM
FastDriver
  • Locked
Expired 1992 Gt Supercharged 331 500 Rwhp Nj
  • 88GTtom
  • Mar 8, 2014
5K
Fox Body Mustangs For Sale (1979-93) Mar 8, 2014
88GTtom
need some input on KOEO, KOER, and memory codes
  • cenok is family
  • May 19, 2011
2K
Fox 5.0 Mustang Tech May 19, 2011
cenok is family
L
  • Locked
SHOW CAR!! ...1988 Mustang LX-49K MILES(331 Stroker/TKO600/31 Spline/Willwood) TX
  • LS3vette
  • Nov 13, 2011
8K
Fox Body Mustangs For Sale (1979-93) Dec 25, 2011
pack018
P
