  • 1994 - 1995 Specific Tech
Is my Car Possessed or terminaly ill
  • Thread starter Thread starter DJHA90
  • Start date Start date Jan 21, 2006
First Prev 2 of 2
DJHA90
581
Texas
Mar 14, 2006
#21
  • Mar 14, 2006
  • #21
Still fighting this. Idles at 2500 RPM. Runs fine on the road -- but idles at 2500. Can back throttle stop all the way out with no change. Checked the blade in the throttle body and it is completely closed. Replaced maf, throttle body, IAC, TPS... still idles at 2500. I bought a motorcycle so I have something to get to and from work. Ideas are still welcome...
DJHA90
581
Texas
Apr 10, 2006
#22
  • Apr 10, 2006
  • #22
Put stock TB back on (including Electronics) and the idle has stabalized. Now all I have is a slight miss. What steps do I take to diagnose a miss?
HISSIN50
34
129
Apr 10, 2006
#23
  • Apr 10, 2006
  • #23
If the miss is constant or occurs at idle, a cylinder balance test is a quick way to isolate a suspect cylinder.
Good luck.
Swarzkopf
973
Pittsburgh
Apr 10, 2006
#24
  • Apr 10, 2006
  • #24
I have a *slight* miss at idle that I've never been able to figure out. Since the car runs fine when driving, I don't worry about it anymore.
DJHA90
581
Texas
Apr 10, 2006
#25
  • Apr 10, 2006
  • #25
New Update: The problem was the IAC. Put the 65mm back on and replaced IAC and it idles fine --- for about 1 minute Then it dies. Start it up and it idles for a minute -- then dies. Any ideas? Miss was the timing.
Leeroy697
2,294
Detroit, Michigan
Apr 10, 2006
#26
  • Apr 10, 2006
  • #26
Pokageek said:
I had similar problems and no codes. MAF went bad. Put a new one on and problem solved.
Me too. I just replaced the electronics and no problem in the last year.
HISSIN50
34
129
Apr 10, 2006
#27
  • Apr 10, 2006
  • #27
I would go through the idle setting procedure after you get the engine nice and warm (180*F+). Who knows where the settings are at now - if you were trying everything to lower the idle before, chances are that it'll be too low with a different TB now.
DJHA90
581
Texas
Apr 10, 2006
#28
  • Apr 10, 2006
  • #28
Idle is fixed but I have one remaining issue - the miss is back
Is there a process for tracking down a miss? I feel close after several months
Thanks
HISSIN50
34
129
Apr 10, 2006
#29
  • Apr 10, 2006
  • #29
Thanks
I posted earlier on another thread, in response to the miss. Anyhow, If the miss occurs at idle, I would do a cylinder balance test to help isolate which cylinder it is, and examine from there.
Good luck.
DJHA90
581
Texas
Apr 12, 2006
#30
  • Apr 12, 2006
  • #30
I took the car to be inspected today and it passed :SNSign:
Now on to the balance test....
Stang95fyvo
70
Vancouver WA
Apr 12, 2006
#31
  • Apr 12, 2006
  • #31
urban96 said:
do you have access to another 94/95 dist? it might be the pip sensor in there
or a bad injector
I had a problem with my car bogging when cold...i changed everything, o2 sensors and IAT and cleaned the maf and checked for vacuum leaks. It ended up being that my injectors were clogged and when they warmed up they wouldnt stick anymore. You may try running some cleaner through it or just repolacing them.
DJHA90
581
Texas
Apr 14, 2006
#32
  • Apr 14, 2006
  • #32
What an ongoing soap opera. So I do a balance test and now it is saying that Cyl 2, 3, and 6 are low contributers... At one point, months back, only Cyl 7 was low. Now it isnt low -- just 3 others.
Does anyone else feel like torching their own car and just walking away?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 15, 2006
#33
  • Apr 15, 2006
  • #33
Is this to mean you got some inj's that are not flowing like they should be
If so ... you could always swap a known good one for a suspected bad one and see what happens
Grady
HISSIN50
34
129
Apr 15, 2006
#34
  • Apr 15, 2006
  • #34
Did you let the balance test run two more times (as it refined the criteria used to evaluate performance)? And those cylinders still all failed?
Time to check out those cylinders individually (check compression, quality of spark, etc. I say this though I cant even remember what the issue with your car was. ).
Good luck.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 15, 2006
#35
  • Apr 15, 2006
  • #35
Good luck.
JT
Are you saying its a good thing to do that test several times cause the pcm can use those multiple tests to somehow evaluate a final sumation
Grady
HISSIN50
34
129
Apr 15, 2006
#36
  • Apr 15, 2006
  • #36
final5-0 said:
JT
Grady
I think it's a good idea to let it run in its completion if it catches a bad cylinder. It runs an initial test and if it passes, that's it. If it fails, one can let it run twice more. With each new test (it will test up to 3 times), the criteria are loosened up and evaluated differently to show someone a small issue vs a larger one.
E.g., if someone's knee hurts when they jump off a 5' drop, one would retest jumping off a 3' drop. If it still hurts, test at a 1' drop. If the knee can handle a 3' or 1' drop, that kind of shows a relative position of how much the knee hinders one's performance.
For those that dont know, the puter cuts the injector pulse to each cylinder, one at a time. It notes the RPM drop with each cylinder being dropped. If one drops less than the others (and compared to what's stored in the computer as acceptable), that suggests an issue. An example is to disconnect a spark plug wire and run the test. That wireless cylinder wont drop the RPM at all and the puter will toss a big warning.
It should be noted that the CBT should really only be used for quick diagnostics of which cylinder might be causing issues. In NO way should one infer that the injectors are at fault. Anything that can cause a miss can trip a CBT code.
Now I wouldn't confuse that last line with what Grady said above - swapping injectors (or even injector connectors) is a cool way to see if the issue moves with the injector. If it does, you found an issue.
Sorry for the ramble.
18mustangs
533
Virginia Beach, VA
Apr 16, 2006
#37
  • Apr 16, 2006
  • #37
I'm not sure what 65mm you're running, but if it's the FMS one try putting the 65mm back on but using the electronics (or just the IAC) from the stock one.
Tim
First Prev 2 of 2
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
