IS my mass Air going out?
tbird187
392
Indiana
I'm unsure of my problem but im thinking maybe the maf is heading out.... during light driving it feels like there is a dead spot in the throttle during part throttle form like 2-3500 just feels alittle boggy, And at idle the car seems extremely rich with the windows down it almost gasses me out... I have ful exhaust out the back and no leaks.... the ful;e pressure is set to 38 psi
302
trickflow intake
ported e7's
trickflow st1 cam
bbk long tubes ect..
stock maf and injectors
Clean the MAF as suggested. If that doesn't fix it, replace the TPS. A flat spot in the TPS will act just like you described.
Picture courtsey of Tmoss & Stang&2birds....
See http://www.veryuseful.com/mustang/tech/engine/ for more good stuff...
If you think the maf is bad, you can have a shop read the voltage at idle and see, mine was really low, .4 something at idle, my car had horrid driveability problems. Or if you have access to a snap on scanner or the ford star tester, those should be able to read the voltage.
