5.0fox Member Feb 10, 2003 410 0 17 buckley/enumclaw wa Aug 9, 2004 #1 Aug 9, 2004 #1 my tranny just started making a slight grind while shifting from third to fourth what could it be? is it my clutch going or my tranny? thx in advance
90mustangGT I felt sorry for girls because Founding Member Jan 15, 2002 2,773 17 89 Dallas, GA Aug 9, 2004 #2 Aug 9, 2004 #2 Maby the clutch isn't fully dissengaging, check the cable. If the syncs are going bad then it might be the tranny.
5.0fox Member Feb 10, 2003 410 0 17 buckley/enumclaw wa Aug 9, 2004 #3 Aug 9, 2004 #3 BUT WOULDNT IT DO IT IN MORE THEN JUST 4TH?
B BaXTeR3221 Member Jan 12, 2004 917 0 16 Orange County, NY Aug 9, 2004 #4 Aug 9, 2004 #4 If it does it everytime you shift from 3rd-4th and your making sure the clutch pedal is fully pressed (yea that sounds obvious, but i'm seen stranger things), its probably your trans.
2000xp8 SN Certified Technician Aug 8, 2003 8,049 1,637 194 NJ Sep 5, 2004 #5 Sep 5, 2004 #5 Not done, just needs a rebuild, and from what i see in person at my local shop, don't let it go too long, problems only get worse. Rebuild kit from hanlon motorsports is like $200, and you'll need a steel bearing retainer. Fix it sooner, not later.
