That's a good point. Are you saying that the boiling water test will cause a good thermostat to fail or that it may not necessarily show that a thermostat is bad because the conditions are different? I just used that trick one time to see if a new thermostat that I dropped worked. Does that mean I ruined the new thermostat by putting it in water or that it may not have shown if it broke when I dropped it? I am just wondering for the future.
I'm sorry if I made a very simple point convoluted (I do it often). You have the right idea - the boiling water test won't necessarily show that a t-stat is bad because it's can't simulate all the conditions the t-stat sees. It's like testing an ignition coil - you can have a spark plug set on top of the intake manifold (that's how test spark) and it will spark decently. But once you put the plug back in the chamber and toss fuel and compression on it, that seemingly good spark might go bye-bye (even though my bench test was good). I don't know if that made sense or not (if not, forget I said it
You definintely didn't break your stat with the boiling water test - if it can't even pass that test, then you don't want it in your car. It's surprising how many new t-stats don't even open near when they should. You're smart to test yours before installing them.
Kevin and I run (in his case, ran
since he drives a zillion HP machine now) the same exact stat. It's neat because it's balanced (there's a shroud around the pellet, which really helps protect it if air pockets or coolant start beating up the stat. Being balanced also meaning that it opens within a couple of degrees of when it should. Some inferior stats take ~15* under high RPM and pressure to fully open). It also flows better and has a jiggle valve. Great bang for the buck for a couple bucks more than a parts store version (Kevin and I live in the desert and do what we can to achieve great efficiency).
I'd note that when I went through the fox's cooling system, I had a new parts store 180. I ran it for one week (in 115*F temps) before going to a Mr Gasket 180. Apples to applies, right? The avg 'hot' operating temp of the car dropped 8*F just from swapping stats (per a mechanical gauge). That was pretty key to me.
Sorry for the long-winded ramble session.
