  • 1994 - 1995 Specific Tech
Is squealing always Pads?
  • Thread starter Thread starter CivicEater
  • Start date Start date Apr 28, 2004
C
CivicEater
579
  • Apr 28, 2004
The pads were supposedly "new" when I got the car about 12k ago and the last few days I noticed a slight slight squeal when slowing down from like 30mph to 5mph. Not every time but about everyother. I cant tell which wheel its coming from and I dont have 30 mins to jack it up and check but I was thinking that just becuase it squeals a little doesnt mean they are necc bad right? Isnt that why they have that "stop squeal"...stuff in autozone....?
85GTlover
704
  • Apr 28, 2004
If it is only happening when you are applying the brakes it likely is the brake wear indicators as you think.
moneypit94
1,723
Macomb, IL
Apr 28, 2004
  • Apr 28, 2004
If they are supposed to be new i would actually guess that your rotor is slightly warped... Actually when you change pads you should probably change rotors too.
That squeal stop stuff is just like a putty/glue that makes your pad stick to the caliper...
C
CivicEater
579
  • Apr 28, 2004
lol I guess the next question is any recomendations on some good pads? Cheaper is better since I am still paying off rebuild/HCI parts.
donjohn
1,757
Irvine - Southern California
Apr 28, 2004
  • Apr 28, 2004
sometimes they're just a little dirty, like a piece of somethin got stuck in there... try washin your car
edit: I reread your statement- the guy probably installed them a long time before you bought em. probably need new pads
AznStanger3v
2,026
Northern VA
Apr 28, 2004
  • Apr 28, 2004
get your rotors turned AND get new pads. at least youll know the two things that arent the problem when you are done
C
CivicEater
579
  • Apr 28, 2004
lol I know the rotors are new, should I still turn them? I heard the backs are a bi*** to do so I was just gonna do the fronts first and see if it goes away and worry about the rears later.
AznStanger3v
2,026
Northern VA
Apr 28, 2004
  • Apr 28, 2004
I think all the pads are pretty easy. When i worked at Toyota of Stafford, I was helping those mechanics work on a Stang that got traded in. The brakes arent that bad, especially when those dudes have Mac impact gun with 1000lbs of torque....bastards. Im still hooking long tubes to my rachets
ChingoChee
366
Fraser, MI
Apr 29, 2004
  • Apr 29, 2004
What if you replace pads AND rotors and they still squeak? Not to hijack the thread, but I bought 45 dollar Raybestos front pads to go along with new rotors and they have squeaked since day 1.
donjohn
1,757
Apr 29, 2004
#10
  • Apr 29, 2004
  • #10
seriously, if they're new its either dirt behind the pads or they're not tight enough. If that's the case clean the backs, spray blueine(sp?) brake pad glue or use a self adhesive shim
AznStanger3v
2,026
Northern VA
Apr 29, 2004
#11
  • Apr 29, 2004
  • #11
yeah, use some brake parts cleaner, spray that bitch down. then, use a good amount of anti sieze/squeal compound on the metal plates that go on the backs of your pads.
302fordracer
738
Vancouver, WA
Apr 29, 2004
#12
  • Apr 29, 2004
  • #12
well I know that the last time I had pads changed for me the f-ing guy didn't apply anti squeal to the back of the pads...so I would even check that...so I just do pads myslef make sure it is done right...too many lazy people
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 29, 2004
#13
  • Apr 29, 2004
  • #13
If you have spoked wheels (see the pads w/o taking off the wheels), then take a look. If the squeeler is touching the rotor, then you need new pads. If it isn't, then run your fingers down the rotor, starting at the outside edge, and go straight down. It should be very smooth, with no bumps. If you feel bumps/imperfections, then you need to return the rotors and put new pads on.
Just remember to follow the correct procedure to "bed" the pads. If you don't go easy on them for the first 200 miles or so, you will have pads as smooth as glass & squeaking will return.
Scott
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
