Is Supercharging a 93 safe???????
willys1 said:
I have a 93 also and am dying for a vortex,but Im too scared,I drive 40,000 miles a year.Its gotta be perfectly tuned all the time :shrug:
You mean Vortec, right? As long as you run a conservative amount of boost and have a conservative tune it should be no problem.
Now seriously, what is the fun in running a very conservative boost when you have a supercharger? I wouldn't trust them for long-term durability as they will fail over time. However, as said, run conservatively and try not to exceed 5-6 psi of boost at the max and you should get by..
5.0LOfFun said:
how about modding a 93 with na mods like heads,cam ect, how do they respond to that with the hyper pistons?
That will be a better route to take. With a supercharger and hypers it's the dentonation that gonna kill your pistons. You could do pretty well with a natural aspirted 5.0. But play your cards right and buy the expensive parts. :D
Set your timming at 20* and pull your spout out and run enough fuel and you wont have to worry about detnation probs or anything like that.
I should be at 10-11 PSI once my power pipe is on
Look at sig...I'd go to the track but I'm in the process of getting a clutch in and my valve cover leak fixed...I wish somebody knew where I can get some NEW stock valve covers... :shrug:
