Is the cold weather doing this to my car?
hey guys,
my car has been giving my alittle trouble now that the cold weather has moved in. When i go to start my car it will start right up no problem then it will stall out on me, then when i go to recrank it over it just cranks and cranks for a couple mins will not turn on. (kinda smells flooded) When i crank it over it kinda stumbles alittle to try to turn on, then it always starts after that. This only happends when the car is completly cold. Has anyone else ever had this problem?thanks alot
Tim
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
I have always had problems starting my car(s) in the winter. They will do exactly what you descirbed. Everytime I get the motor up to temperature the car will be fine when I have to restart. I have always chalked it up to the cold natured-ness of the car.
EFI cars are supposed to crank and fire quickly on the first crank, even in cold weather. Ford when to great efforts to make sure that happens. When an EFI car doesn't start up quickly, something needs a bit of tuning or repair.
I completely agree. I bought the vert last Thanksgiving (at the onset of cold weather for us in Michigan.) I spent the winter fixing the Heater Core and a coolant leak out of the timing cover. I didn't have a chance to do any type of tune up work or diagnosis. In the spring ('05) I changed out a lot of tune up parts and dumped codes (code 33 - fixed) and the car ran so much better.... This winter will be the true test of my cold weather problems from last year. As of our first snow fall and extended cold weather, my car has started on the first crank and ran without stalling.
