Is there another fuse?
LaserSVT
3,542
233
My cigar lighter is not working and its pissing me off :fuss:
My aux power point works and fuse #1 which is supposed to be for the lighter is good but there is now power going to it (the fuse) :notnice:
So just to reiterate: No power at fuse for gigar lighter. Does have power at aux power port. Is there a secondary fuse for the cigg lighter?
Any ideas?
well, if the fuse is blown there will be no power to it :p
Did you check all fuses? One has to be blown causing the cig light not to work. Also, check the connection under the shifter bezel/boot. That is were they connect I believe. Could of came loose :shrug: but I am betting on a fuse.
Turns out I was checking the starter fuse :nonono:
If I held the owners manuel upside down then I can see the layout the right way :doh:
No wonder there was no power to the fuse. That one would only get power in the "crank" position :nonono:
:rlaugh: I deserved that as i had replaced this fuse before :nonono: The damn owners manuel just dont look right when you go under there :(
