That cam has a 114 LSA so shouldn't have taken much to tune it w/SD. I have not owned a SD car so I'm guessing when you say it was tuned for the cam your talking about a chip? Can you post your time slip (or write down) so we can see how it was driven. Where is timing and fuel pressure set at? I would work on tune first to make sure it is dead on before spending money on it. If tune is on I would consider pulling the chip then making a run to see if that tune is off.
When tune is correct then the first then you should replace is stock intake for Cobra. Forget the ported stocker if heads are in the plans, Cobras can be found used for short money.
Stock cam does work well with minor mods but the cam you have isn't all that bad and not worth pulling IMO.
Almost forgot if those are stock springs they need to come out NOW!
