Is this even remotely repairable? (pic)
94' Five.0
206
Raleigh, NC
I'm more than embarrassed to post this pic :nonono: but I'd like to get some input on what I can do with this. The clear has been peeling in this spot for a while now. I've honestly just been putting off dealing with it since I was planning on repainting it next summer. However since we're getting into the winter season I'd like to prevent any damaging rust until I can really focus on overhauling the whole car.
I don't know much at all when it comes to paint work. Is it even possible to wetsand the edges on this spot and blend in some new clear for protection? I'm not expecting any miracles, but something that looks decent.
On a side note, the car has been sitting out in the weather for a while and rest of the paint has some pretty nasty buildup. I was going to clay everything this weekend but have a quick question. Should I use some kind of polish or rubbing compound before I clay?
Thanks
If it's just to prevent rust till the spring, give it a fine sand along the edges to pick up the loose stuff, then give it a once over with a spray bomb full of clear coat from Pep Boys. It certainly couldn't look any worse than it already does. :nonono:
I know I'm a little late on this, but you could grab your paint code and pick up a can of Duplicolor for that code and spot fix it. It may not match perfectly, but if you wetsand and clear it, it'll look a ton better than it does now.
Yeah, I ended up wet sanding the loose edges down and spraying a couple light coats of clear just to protect the spot. It is still very noticeable but doesn't look near as bad as the pic above. Come this spring I'll have to look into getting the whole car painted. Thanks folks :nice:
