Is this normal
GREG91GT
207
MISSOURI
The other day at the track i started the car and pulled the spout connecter out and checked my timing, it was at 10 so i put the spout connecter back in and it was still at 10 is this normal or should it change i have never payed much attencion to it before,when does it begin to give advance? :shrug:
In my experience, the puter should have kicked the timing up some as soon as the SPOUT went back in (the 94 GT was the last stang I timed, and it kicked in 10* just from installing the SPOUT).
You might have a cut wire in the SPOUT connector harness.
Good luck.
If you suspect the connector, you could put a jumper wire in the harness instead (even a paperclip would work). I sorta doubt the issue is the connector itself, unless it looks like poop.
How does the wires look?
Good luck.
