  • 1994 - 1995 Specific Tech
IS this possible for $2,000?
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date May 16, 2005
1 of 2 Next Last
OrangeMustangGt
1,976
Cape Cod, MA
May 16, 2005
  • May 16, 2005
Im looking for a supercharger, and cant seem to find much. I have a welder and skills, What do you think, could i make an EMMISSIONS LEGAL Single turbo kit myself for under 2k with all the parts? meaning, Single turbo(possibly masterpower), Intercooler, piping, 42lbs, MAF, Single 3" cat.? what do you think? is it possible? In MASS i was told that as long as it physically passes emmissions its fine....or i could buy a sticker for ~100 if i had to. What do you think? i KNOW i could make it myself, however can i do it in this price range do you think? otherwise ill just make it easier and bolt up a supercharger. what would you do?
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
May 16, 2005
  • May 16, 2005
Too bad Im not ready to sell mine. WHen I do next year, Ill prolly ask for a little less than that WITH the chrome power pipe.
Good Luck
RC
BlackVert
5,589
9
98
Bethesda, MD
May 16, 2005
  • May 16, 2005
I am doing it for about $1500, but I am having my hot side fabbed by someone else, no intercooler, and I already have a TwEECer and 42#ers. If you do it yourself, you should easily be able to make it for under $2000.
figure:
$400 for a used turbo
$150 for hot/cold pipes
$200 for a wastegate
$300 for 42#ers
$100 for a fuel pump
$150 for an intercooler
$100 for miscellaneous stuff (oil lines, bungs, clamps, ...)
$100 for a BOV (if you have a manual)
that's $1500, leaving $500 for a tune.
OinkAodeOink
3,026
Daytona bch, Florida
May 17, 2005
  • May 17, 2005
I'll tell ya.. it's the small things that add up, but none the less, you can do a single setup for under $2k for sure.. Actually a couple years back I sold my S trim for $1600, and managed to do a nice single setup for about $1200 intercooled.. (already had injectors, mass, fuel pump, tweecer)
I don;'t see why you can't weld on a cat or two, and pass emissions..
shelbe67
309
May 17, 2005
  • May 17, 2005
you should go to turbomustangs.com they have a lot of junkyard builds there maybe some one can help you out a little the only thing is do some research on the site first they dont really like it when you want them to do all the work for you:}
OrangeMustangGt
1,976
Cape Cod, MA
May 17, 2005
  • May 17, 2005
thanks guys. I allready have a chip so a re-tune should be cheap. I really think i am gonna do this. I was thinking of using a masterpower turbo, possibly a t-70. So that, Intercooler,Pipes,cat,Wastegate,Bov,Inj's and a maf cant be too much right? hmm....ill crunch some numbers i guess.
OinkAodeOink
3,026
May 17, 2005
  • May 17, 2005
Im not sure how much a cat conv would cost, but your going to have to find deals to stay under $2k for everything.
figuring new parts, except BOV..
MP T70 w/ V band & clamp- $750 ish
hotside piping/headers/clamps- $250-300
cold side/conectors/silicone- $150ish
intercooler- $250-300 Ebay cooler
BOV- used 1st Gen DSM- $40-50
Wastegate- Tial 38mm- $210-$220
Injectors- 42's $ 300
fuel pump- Walbro GSS340- $110ish?
mass air- ProM Univer - $300 ish
Those are just some ballpark figures of parts I would recomend.. and the total would come close to $2400
I would recomend finding used parts, if you wana keep things under budget, such as an intercooler, turbo, wastegate, and bov.. You could buy injectors and mass air used also, and save big. This is figuring you have a welder, and know a thing or two about turbo systems and design.. It's not rocket science, but believe me when I say, I've seen plenty of cobbled up mess called turbo kits. Take your time and do it right, and you will reap the rewards of boost!!
OrangeMustangGt
1,976
Cape Cod, MA
May 17, 2005
  • May 17, 2005
ok i was just on turbomustangs, and i was told there is no way to keep the a/c and most important, my smog pump with flipping my shirty headers. I really think i need the smog pump to pass emmissions right?
boostaddict5_0
37
  • May 17, 2005
Dang Green your all over the place . You CAN keep your AC but your going to have to make your own drivers side header or run it the right way, and go between the flywheel back up to the passenger side. Your ****ed on the smog pump=custom header.
Y
yellow1995Cobra
2,959
Massachusetts
May 17, 2005
#10
  • May 17, 2005
  • #10
Forget the dumb emmissions, theres TONS of people who will pass ur car for cash. Thats what ive always done, alot less headaches.
Personally, i would just bolt on an s trim and have fun or buy a kit already made. Your gonna take on a MAJOR project.
OrangeMustangGt
1,976
Cape Cod, MA
May 17, 2005
#11
  • May 17, 2005
  • #11
yeah man, all those problems are really makin me swing twords a superxharger
boostaddict5_0
37
#12
  • May 17, 2005
  • #12
Green don't punk out dude. Just pull your smog and your AC, then run shorties. Don't worry about the smog testing. Hell I might sell you my custom drivers side header...cause I took off my AC and I don't need the header anymore.
AZ95GT
326
Arizona
May 17, 2005
#13
  • May 17, 2005
  • #13
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33741&item=7973556092&rd=1 ????
OinkAodeOink
3,026
May 17, 2005
#14
  • May 17, 2005
  • #14
I knwo for a fact you can keep a/c.. You could keep smog, if you made a custom pass side header.
Actually when I finish BlackVerts setup I will post some pictures.. His setup will retain all accesories except smog. I have found a way to use any shorty header as a drivers header with little customization.
BlackVert
5,589
9
98
Bethesda, MD
May 17, 2005
#15
  • May 17, 2005
  • #15
i can't wait!
OinkAodeOink
3,026
May 17, 2005
#16
  • May 17, 2005
  • #16
BlackVert said:
i can't wait!
to finish it, yea me too!!
Learned a few things from your setup so far.. If it werent for the burns and fumes, I would do this stuff more often.
BlackVert
5,589
9
98
Bethesda, MD
May 17, 2005
#17
  • May 17, 2005
  • #17
hey, maybe it'll help yours turn out better too
94gts
873
Carmel, New York
May 17, 2005
#18
  • May 17, 2005
  • #18
i have no smog pump(or ac) but an idler in place of the pump(a/c is gone and bypassed). will this need to go??? if so, how do we bypass the smog location on our cars do to the location of the tensioner?
BlackVert
5,589
9
98
Bethesda, MD
May 17, 2005
#19
  • May 17, 2005
  • #19
http://eleanor.pro3i.com/showthread.php?t=544697
94gts
873
Carmel, New York
May 17, 2005
#20
  • May 17, 2005
  • #20
the tensioner will swing that far?
1 of 2 Next Last
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
351w turbo build.... Turbo guys teach me things...
  • Kid wita 5oh
  • Oct 22, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2025
General karthief
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 26, 2025
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
