ISSUES WHEN COLD OUT!!!!
  • Thread starter Thread starter Bosko5.0
  • Start date Start date Apr 18, 2008
Bosko5.0
1,067
longwood, FL
Apr 18, 2008
  • Apr 18, 2008
For some reason when its cold out my car starts to shift crappy then while holding throttle at steady rpm the clutches start to slip. When i hit tap the gas pedal the car jumps forward like the converter is locked up.
Also the afr at 15-20% throttle is around 12.1 when it should be 14.5. WOT runs at a 10 afr but when I let off the gas the afr jumps to 20 and hangs there till it drops to 14.8- 15
This only happens when its cold and not all the time, Ive tried unhooking battery and reseting the computer but still nothing.
I went to work with it running like that and turned the knob on my tweecer to a different setting And left it for 8 hrs and it all went away but it was hot out. changed it back to the first setting and still worked Fine. but When I tried this the night before while it was cold out it did not fix the problem.
Now my Question is What would cause this issue?
And how would I go about fixing it?
Bosko5.0
1,067
longwood, FL
Apr 20, 2008
  • Apr 20, 2008
nobody has a clue???
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Tips for WUE and ASE tuning
  • Mustang5L5
  • Oct 9, 2025
  • Digital Self-tuning Forum
Digital Self-tuning Forum Oct 10, 2025
gkomo
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
