ISSUES WHEN COLD OUT!!!!
Bosko5.0
1,067
longwood, FL
For some reason when its cold out my car starts to shift crappy then while holding throttle at steady rpm the clutches start to slip. When i hit tap the gas pedal the car jumps forward like the converter is locked up.
Also the afr at 15-20% throttle is around 12.1 when it should be 14.5. WOT runs at a 10 afr but when I let off the gas the afr jumps to 20 and hangs there till it drops to 14.8- 15
This only happens when its cold and not all the time, Ive tried unhooking battery and reseting the computer but still nothing.
I went to work with it running like that and turned the knob on my tweecer to a different setting And left it for 8 hrs and it all went away but it was hot out. changed it back to the first setting and still worked Fine. but When I tried this the night before while it was cold out it did not fix the problem.
Now my Question is What would cause this issue?
And how would I go about fixing it?
