Electrical Issues with 91 mustang with a 93 5.0 motor
Theekinghumpy
10
Indiana
So I am new to the mustang world and I got a 91 mustang gt manual off a friend with no motor or transmission. Then another friend sold me his 93 motor and manual transmission. We dropped the motor in with no issues but I sent it to my local mechanic and he said he is having issue matching a engine harness. Is this a compatibility issue or does my mechanic not know what he's doing?
Harnesses did change a few times between 87-93.
Best to stick with year of the body. Engine doesn't matter. An 87 engine will run in a 93 and vice versa. All that matters is the wiring for the year of the car, the ECU and manual or auto
The engine mounted fuel injection harness has the same wiring on all years between 87 and 93. Some of the wires different colors but the connector pinout is identical for 87-93 engines.
See the graphic for the 10 pin connector circuit layout.
Computer wiring harness connector, wire side
Computer wiring harness connector, computer side
The following are diagrams courtesy of Tmoss & Stang&2birds
Complete computer, actuator & sensor wiring diagram for 88-90 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
5.0 wiring diagram for Fuel Injectors, Sensors, and Actuators
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
TFI module wiring for 94-95 Mustang GT
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-IgnitionControlModule.gif
Complete computer, actuator & sensor wiring diagram for 94-95 Mustangs
Ignition switch wiring
O2 sensor wiring harness
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
93 power window wiring
T5 Cutaway showing T5 internal parts
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
Starter circuit
Alternator diagram for 94-95 Mustangs.
Reactions: RichC93
