ISSUES!!!!!
jhr302
48
well , i'm having issues with the mustang m,, its an 88 gt , the issues I'm having are with it over heating , it has a flex-a-lite electric fan , new water pump an i just installed a 3 core all aluminum radiator , i let is run at idle to get the coolant through an i was getting some bubbles of air but not many , the only reason i went with a bigger radiator is cause it was over heating before an now its doing the same thing , i have a 180* thermostat in it , i sat in the car an watched the temp rise all the way to 250 ( autometer gauge ) , so the question is , why would i be over heating like this ??? i need to figure it out soon , if not im gonna sell the damn thing:mad:
Sounds like air in the system. I like to raise the front of the car, I use ramps, take the cap off the rad fill with water/coolant and run the motor till the t-stat opens and you can see movement of the coolant.
I also unplg the fan to make sure it gets nice and warm to gat the coolant moving and push the air out.
Or just sell it.
it could still have more air in it. When I did my rebuild I had a similar issue. I took the T stat out to make sure it was in the correct way with the jiggle valve at the top. it was so, I took in the house and put the T stat in a pot of hot water with a meat thermometer and watched for it to open as the heat went up. it worked fine so i put it back in. The 2 wire temp sensor looks to be the highest point so I loosened it up and let the car run until it stopped hissing air out of it. hope that helps.
both sound like good ideas , ill give it a shot it a shot tomorrow , i know the stats working , i checked it already , now with the i know this is gonna sound stupid , but the long part go in tword the block ? correct ? my temp guage was reading 250 but the intake was not hot an niether was the coolant in the radiator , just for more info , an no i really dont want to sell it , i have to much money invested in it
it really sounds like air in the system if you check the coolant after the car has cooled for an hour or so the level will probably be low which means you got the air pocket out
everyone is giving some sound advice. I find these cars can be a pia to get air out of. when i did my coolant system over I had a stuck pocket and had to top off the overflow after a few trips. do you have the standard black magic or extreme ( or what ever they call it) I have heard some say the basic flows really marginal cfms just a though but it does sound air bound.
just the basic one , i was told to get a fan out of a 94-95 gt , but i havent been to the junk yard an dont feel like buying a new one , im gonna try the air thing first see what happens
so i thin k i found out what my problem was , the water pump i have on the car is a defective one , its not pushing water through the block , i did what you said ( undo the two wire temp send ) after running it at idle for a bit , gauge red 210 degrees , i unscrewed it an nothing , i took it all the way out an there wasn't even an coolant in the lines , i had the heat on to , so there should have been fluid in the lines , so i ordered up a new aluminum
