Ok I fired up my newly rebuild 306 (95 Cobra) for the 1st time. I was able to get it to idle to set timing (14*) and take for several short rides but the idle is not consistent. By the way, she pulled strong with no hesitations. I've read and been told that with the 94/95 computers it's a hit or miss with modifications. Also, it seems to be running rich or lean (not sure need help determining). And the water temperature seems a bit high for me (210*). However, according to the Mustang Service Manual the fan cuts on at 221* (why so high) so that seems to be the normal temperature for these cars (don't like it). Note: The head gaskets were installed properly and there is no air pocket in the cooling system. Below are the specs.
1. Stock crank
2. Probe forged pistons
3. Eagle forged rods
4. Lunati cam: intake 218*(.500), exhaust 226*(.510)
5. Crane gold 1.6rrs
6. Crane lifters
7. AFR 165s milled for 10:1 CR
8. Edelbrock RPM intake (upper/lower)
9. Fluidyne Radiator (180* TS)
10 MAC CAI
11. Granatelli 75mm MAF
12. BBK 70mm TB
Here are the questions.
1. What do I need to do to get the idle right (consistent)?
2. What do I need to do to get the water temperature down to around 180* or so?
3. If a chip is needed, which chip is best for 95s. Is it best to phone order and install or have dyno tuned and installed.
4. How do I know if its running lean or rich and how to correct the situation?
5. Any other suggestions are welcomed as I've been out the game for awhile.
Heeeeeeelllp. Thx
1. Stock crank
6. Crane lifters
10 MAC CAI
12. BBK 70mm TB
Heeeeeeelllp. Thx
