Listed is a Stainless Steel direct fit D.O.T. certified PTFE (Teflon) lined rear brake hose J&M part number 22515R and fits many V8 Fox and SN95 Mustangs. This fits over the rear axle and will reduce brake pedal "sponginess" and help brake responses. There are installation instructions posted here: https://www.americanmuscle.com/87-98-rear-diff-hose-cust-install.html
Note: Ford discontinued Flex Hose part number: F4ZZ2282B
These are now located in Bradenton, FL (34210) and I am asking $25/obo
From J&M:
"These brake hose assemblies use true OEM style direct replacement non-universal fittings to achieve proper factory hose routing and fitment. Expansion of stock rubber hoses causes a spongy brake pedal feel and loss of initial braking force. Installation of our PTFE-lined stainless steel hose assemblies will give your car a firmer pedal, quicker braking response, and easier brake modulation. Every hose is tested to 3000 psi to guarantee a leak free hose assembly. These are made by J&M Products in the USA."
Stainless Steel Brake Hose features and benefits:
Suitable for all applications including extreme racing.
Exceeds the latest DOT standards backed up by independent laboratory reports.
Direct OEM Fit each fitting is of OE design so NO adaptors are necessary.
Trivalent zinc plating exceeds DOT salt spray test.
Design allows high temperature operation and longer life.
Every hose is pressure tested to 3000 psi (207 Bar).
Quicker brake response.
Better brake modulation.
Every hose is stamped with U.S. DOT registered number.
Outer protective covering.
Fits: 1987-1998 Ford Mustang
Also, don't forget to check out my Mustang Cobra rear brake calipers listed as well.
Pictures are of the actual item listed
From J&M:
