  • 2005 - 2009 Specific Tech
JBA LT rattling
  • Thread starter Thread starter PanhandleGT
  • Start date Start date Oct 11, 2005
P
PanhandleGT
  • Oct 11, 2005
Anyone with JBA LT's have an obscene amount of vibration after install. Also have JBA offroad H and Magnaflows...Its so bad I think something is going to fall off! Took it to several exhaust dealers to check for leaks and proper installation and all is well according to them. I contacted steeda prior to install and asked if different motor mounts were necessary and they said NO, THERE IS PLENTY OF ROOM...(I bought LT's from them). Anybody encounter this or similar problems and are there any solutions??? Any help would be appreciated.
K
kfddakota
28
temple, texas
Oct 12, 2005
  • Oct 12, 2005
According to JBA and their instructions they highly recommend the steeda motor mounts which i installed but yet my passenger side collector still hits the framerail and it sounds horrible. Not much i can do about it now since anything i do will require me to dish out a lot more money to fix it. So if you come up with a solution let me know.
P
PanhandleGT
  • Oct 12, 2005
Exactly the same thing with mine, passager side collector vibrating against frame. How can you stand it? I visited a local mustang performance shop and they recommended heating up the frame and hammering it out just a bit where it is rubbing. I dont like the idea but the alternative really stinks.
RandyB
307
Tx.
Oct 12, 2005
  • Oct 12, 2005
Panhandle,
Aren't you pleased with the R&D work that your first two major parts vendors did for you? That being JBA and the Mustang Tuning. They need to make it right...
D
delurker
169
  • Oct 12, 2005
kfd, did you install 2 hard/2 soft bushings, or 4 soft? I wonder, because I had the hard (black) bushings installed on the side the engine rotates to and mine don't hit.
cleveland
579
SF>...
Oct 12, 2005
  • Oct 12, 2005
Answer: BMR K-Member with Solid Motor Mounts...
This is why I am holding off on doing LTs.
-Dan
K
kfddakota
28
temple, texas
Oct 12, 2005
  • Oct 12, 2005
I installed the black bushings and it still hits. Looking at the collector itself i can barely see between it and the frame. I'd be hard pressed to stick a toothpick in between it. So do you mean you have both black bushings on the passenger side or like the instructions said?
D
delurker
169
  • Oct 12, 2005
Shop installed them like the instructions. It was worth a shot...
Mine are pretty close, but IIRC, I could probably almost get a writing pen between the header and frame.
L
LordHalbert
56
  • Oct 13, 2005
If the tubes are rubbing against the frame, try some heat resistant material in between them to dampen the vibration.
RandyB
307
Tx.
Oct 13, 2005
#10
  • Oct 13, 2005
  • #10
That's a good suggestion.
You could also get a set that fits properly. It surprises me that a company like JBA would put out a header that has tubes that rest against the frame. I understand tolerances and all, but lets get a little better than that.
A
adiga
Houston,Texas
Oct 24, 2005
#11
  • Oct 24, 2005
  • #11
i had the same problem
dont freak out i had the same exact problem!!! we went crazy trying to figure it out, we almost took the dash board apart...THANK GOD WE DIDNT. anyway i dont know what to call the part but it is a small welding coming out of the headers that are wilded to the headers from one side and attached to a piece of rubber from the other side....i really dont know what they are called but it raddles agains a bolt which is directly above it...you might want to check both sides...all you have to do is bend that metal thing that is coming out and you wont hear a sound....trust me it is very silly....if you have any Q's you can e mail me and i'll try to explain it a little better
adiga66@hotmail.com
K
kfddakota
28
temple, texas
Oct 24, 2005
#12
  • Oct 24, 2005
  • #12
I finally had enough of my header collector hitting the frame rail today so i decided to call JBA to tell em my mind and didn't expect them to help me out at all. To my amazement his first response to my dislike of the header was he was gonna ship me out a new passneger side header today and it should be there in 2 days; no questions asked. All i have to do is send him the old header within 30 days or they'll bill me for it and i have to pay return shipping which shouldn't be too much by ground. Good customer service in my opinion. But like yall said we never shoulda had this problem in the first place.
JTGrant
775
GA
Apr 7, 2006
#13
  • Apr 7, 2006
  • #13
did that fix your problem, because I just ordered a set of LT JBA ceramic stainless.
anthony05gt
1,262
Maryland
Apr 7, 2006
#14
  • Apr 7, 2006
  • #14
I have the JBA longtubes and stock mounts with no problems. 490rwhp and the stock mounts are holding up. I think it's just a case of no 2 headers or cars are exactly the same.
JTGrant
775
GA
Apr 7, 2006
#15
  • Apr 7, 2006
  • #15
sounds like it
P
Pro Mod
236
Wharton, WV
Apr 7, 2006
#16
  • Apr 7, 2006
  • #16
Ditto, I think that's exactly what it is. My passenger side header collector is very close to the frame (at the collector weld like mentioned above) but it doesn't rattle.
I actually had a rattle/vibration in mine, but it was the 2 H-pipe hangers hitting the 2 bolts on my crossmember. I just heated them with a torch & pried them down about 1/4".
anthony05gt
1,262
Maryland
Apr 8, 2006
#17
  • Apr 8, 2006
  • #17
Sometimes you gotta do what you gotta do!
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
20K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
Engine Rocker Noise after Aluminum heads and 1 piece CM Pushrods
  • 79pace
  • Apr 12, 2022
4K
Fox 5.0 Mustang Tech Apr 19, 2022
Monkeybutt2000
M
R
Fox Closed PCV System, Dual Valve Catch Can
  • RTW0223
  • Dec 6, 2019
15K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 30, 2021
jay98
Getting my car decent. Looking for thoughts on this long list.
  • Wayne Waldrep
  • Jun 10, 2019
  • 2 3
10K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2020
Mustang5L5
Spec Stage 2 Plus Premature Clutch Failure
  • Saberstang
  • May 2, 2017
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech May 4, 2017
Saberstang
