Jeep build becomes Pony? 8.8 Q's
StanglovR1
79
Boston
Ok so get this. I built a couple jeeps (still doing a cj5) but i had a built cherokee as my dd. It was a full out build and i had plans of putting in larger/stronger axles and steeper gear ratios. So i went to the pick and pull and snagged an Exploder (yes i ment to spell it that way) 8.8 axle with a posi lock for $100. it was nearly a bolt in for a cherokee minus some leaf perches.
Well the jeep was doomed by a 16year driver and a street light pole, took it clean out of the ground lol. so now im sitting on this axle which is half apart and i got this dim/bright? idea of changing out the 3.73 and posi and putting them in the stang? thoughts?
I see you've got a 95 XJ coool! So you'r refering to the the axle shafts correct?
How many spline is the mustang?
Can i use the Exploder axle shafts?
If i just took out the diff internals in the explorer and put them in the stang will they match up with the mustang pinion gear?
