Juice for my 03
Hey all well the bug is biting again so I have decided to add a 70 shot of giggle juice to my 03:nice: . The question is can I run a 70 shot without upgrading my fuel system and getting a new tune? My ride is currently dyno tuned by Ed at ASAP in PA so its a really good tune right now. Let me know what you all think. I'll only be hitting the juice at the track, and its not my daily driver. Thanks all
Id save the money for the kit and add it towards a Kenne Bell or even a ported eaton. anyway i have wanted a 03 svt cobra since they came out but ford wouldnt give me a good monthly. have fun with it............
upgraded fuel system, maybe not, if you are less than 480-490 HP and real tuner makes sure you don't go lean at higher rpm.
can you do it without a new tune? .... ahh you could, but you will probably blow your motor, no one can stop you from doing something stupid, but if you listen to others that have gone before you, do a few searches and talk to your tuner BEFORE you purchase the HP increasing parts, you would realize you will have to retune your car to make sure it doesn't go lean when you dump in the sauce, no matter how you apply it.
did you do a pulley swap? If so you have to change your program, i belive that most programs for the pulley advances timing and i think thats the last thing you want to do when spraying nitrous. As long as it wont put you over 550 hp your stock fuel system will be fine. Use a dry kit and spray before the MAF and let the factory computer add the fuel, then you dont have to worry about a fuel solinoid not working or fuel puddling. Spray a 50 shot and it will put 70 - 80 at your wheels. run a window switch no mater how you spray and have it re tuned. i think it will be absolutly safe as far as your motor is conserned
