Junkyard Gt40p Questions
93-2.3
99
PA
I'm about to do a gt40p head swap what all can I reuse on the swap and what do I need new valve train wise. Can I use the stock ho motor lifters and pushrods? What rockers can I use the gt40p explorer rockers or can I use the rockers off my e7 heads? Last question is what will I need for valve springs? Will be running either stock cam or maybe a smaller ford letter cam like b or e cam. (Yes I know there are better cams out there)
The lifters can stay unless suspect of wear. Pushrods and Rockers from the E7 or the GT40p will work. Pretty sure the pushrods are the same length, mine were, and even when I compared both engines they were. When all else fails measure, and check pushrod length with a checker.
Change the valve springs
B cam is known to crack blocks. I would stick with the stock cam.
Upgrade the valve springs, replace the guides and retainers and bolt em back on. The rockers are the same for both head as are the pushrods. The key here is to spend as little money as possible. If you start getting crazy with the heads and valve train your costs will start approaching aluminum head territory.
Yep I'm trying to stay cheap just want a slight power increase and got the heads dirt cheap (60 bucks) I'm gonna do new springs, and valve seals, also lap the valves but other than that not trying to put too much into them thank you all for the I'm put so far
Alexparts has good cheap springs for GT40p heads
