Just a quick brake question...
Adams91LX
689
12
29
Plano, TX
How much better is the sn95 cobra rear disc compared to 93 cobra?
The v6/gt sn95 is a solid disc of a very similar size to the 93 cobra vented...
One day I will upgrade to 13" up front.. Right now running 95 v6/gt up front and a modified 93 cobra set up out back...
Would it be worth it to upgrade to sn95 cobra brakes out back too?
The car will see some autox... but mostly street...
Opinions?
if your auto-x'ing some, i would go for it.
if your running v6 stuff up front, i'd go to a cobra setup there first. it will cost about the same, and you will get more braking for the $$$ imo.
No I was definitely planning on going cobra up front... :nice:
I was just wondering how much better the rears would be or if it would be a noticeable difference.
10" vs. 11.65"
The cobra is better... but how much better?
Unless you are open track racing...you will never notice a difference.
I auto crossed my 03 gt with cobra fronts and gt rears....braking was still great with the fronts doing most of the work.
I only put cobra rear disks on the rear of my fox for show really. Never liked the puny gt rotors in a big open. However I have to turn my adjustable pv down a lot to keep them from locking in a hard stop.
If you asked me to rate the rear setups, imwould put them like this
Sn95 gt/v6 ---- 93 cobra ---- sn95 cobra
Most people go with cobras all the way around just to ease install and not have to **** around with which MC and booster, I did it because of my cars usage, but IIRC you do similar things with your car so i say go for it, but definitely do your front first as they do about 80% of your braking anyhow.
^^I wish our car's were anywhere close to the same use... mine is light-years and an MM catalog away from being like yours... I still need a ton of help suspension wise... but I digress.
I did some more digging tonight...
The 93 Cobra and 03 Cobra run the exact same piston size for the REAR caliper (36.5mm or 1.4375")...
Only real difference in actual braking ability would be the larger diameter of the rotor...
Expert Brake Advice
So... I'll definitely start digging/collecting for the Cobra swap parts I'll need for the front... but the rear's seem mostly worthless minus looks and the larger rotor area...
Expert Brake Advice
Thanks, its far from done or perfect.
End goal is the same usage though right? I say go for the rear cobra brakes, ties the wheels up nicely and if you're doing an SN axle you can add ABS(in the works for mine) but only once you've done the front and everything else to support it.
93 cobra caliper is 1.78" (45mm) piston
Someone should tell factory five their website has incorrect information then...
My question has been answered tho. I do plan to occasionally autox/dd my mustang. I'll have to pick more carefully a balanced set up so I don't hate my car as a daily or hate it at an autox... For the most part those two things are mutually exclusive.
Well, think of it this way...
Larger rotors are great at absorbing heat. This is where they shine. The 93 cobra has a larger calipers, but smaller rotor than the cobra. Leverage is key, but caliper size plays a roll too.
Cobras are really more of open track cars, so their larger brake rotors help dissipated accumulated.heat over the course of a track. With autocross, you don't build as much heat because your speeds aren't as great.
In terms of building a balanced setup....well that's what adjustable prop valves are for. You can really reduce the pressure to the rears to control how much biad you have
Nice. I'm always impressed with the technical/informative knowledge of this site and it's members. An adjustable PV is a must anytime stock braking system is modified or changed..
Merry X-mas everyone...
