just another 5.0 swap question
hotrod101786
21
just picked up a 93 coupe. wantin to dip the good ol 5.0 in her. cars already a 5 speed so i know thats a nice lil headache saved. im just wantin to know the bare essentials on what i need. im not wantin this to be a perfect factory look. as far as i know i need a complete 5.0, ecm, harness, throttle cable and mounts. i can get by with my brakes, suspension, tranny and rear end right?? i know swapping those would be a good idea in the future but i just need that 5.0 in there for the time being. everywhere i go people listen to hear that bad boy coupe start up and they laugh when they hear the clankin, pissed off bumble bee sound of the 2.3 crapbox. im just needin a list of the minimal things i need for the swap and average prices. :nice:
yeah you can get away with the 4 cyl suspension, tranny and rear but its definitely a good idea to get them swapped out with some v8 stuff sooner than later. you'll have to change over the brake and fuel lines, they run on the opposite side of the car than the 4 cyl cars do. you have to get a different pilot bearing if you want to use the 4 cyl t5 too, as the snout on the input shaft is a smaller diameter. you have to get one from like an 80's ford ranger, i don't remember what year exactly though. then of course, you'll need a new exhaust and transmission crossmember as well. that's all that i can think of at the moment, i'll let you know if i remember anything else. good luck!
oh yeah, it's been a while since i've done a conversion, but i'm pretty sure the radiator and rack and pinion are different too
Posted via Mobile Devicewell how much cheaper/easier would it be to put a carbd 302 in?
well if you're building a new motor from the ground up, it'd be cheaper to go carbed since fi stuff can get expensive, but if you just pull an fi motor from another car and drop it in, it'll be cheaper that way, actually, because otherwise you'd have to spend more money on a carb setup. it might be a tad easier going carbed, as far as dealing with the harness, but imo, FI is the way to go.
